Question about LG Washing Machines
Error code SE how to fix it what dose it mean
    Brigadier General:
  • 6,966 Answers
To my knowledge, error code "SE" indicates a sensor fault. The sensor is attached at the end of the motor. Its function is to monitor the speed and direction of rotation. If the sensor is faulty, the logic controller would not be getting one of its inputs and therefore would halt the system operation. It is relatively easy to replace since it is only held by a single screw and attach to a single connector. There are however a few instances that the sensor is OK, it is the wiring/attachment to the controller board that is faulty or the controller board itself.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
What dose code 0002 means in canon ir 2520
that error means there is over temperature detection . you need to clear that error from service mode
May 04, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Mod SMH1816S Shows SE error only 2 yrs old How to fix
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see
See my profile picture if you need more help.
Nov 15, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Why does my microwave not work? It displays what I believe is an error code.
. The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
-korrinA S
Mar 03, 2015 | Kenmore Microwave Ovens
How to fix a se error code on a kenwood microwave
Do you mean KENMORE microwave? SE error code typically means a bad control panel keypad.
Sep 05, 2014 | Kenwood Microwave Ovens
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
Call local SAMSUNG service
Look for the 1-800 number on the back and give them a call.
Jun 10, 2014 | Samsung Microwave Ovens
Canon i-sensys MF8188OC with error E000, it can not work, what does it mean?
The error code E000 means that the fuser is not warming up correctly. You can try to unplug the copier for a few minutes. If that dose not fix the poblem, you will need to have the fuser unit replaced
Jul 26, 2010 | Canon Office Equipment & Supplies
What dose e13 means
error, code 13 for service man
Oct 04, 2009 | Black & Decker Heating & Cooling
Error code,
The needle jumoing to 7,000 on the RPM dial means that the EXUP valve is stuck. This is a common problem with Fazer 1000's. Although Yamaha don't recommend any maintenence I strip and clean mine regularly to stop it from sticking. According to Yamaha - a sticking valve is not a serious problem and the bike can be ridden until you get time to fix it.
Jan 26, 2009 | 2005 Yamaha FZS 1000 Fazer
Don't know what that code means but....
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Aug 10, 2008 | Panasonic DVD-LV50 Portable DVD Player...
Washing Machines Logo
106 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
