Question about Samsung Televison & Video
Samsung VR 5709 VCR seldom ever used because of sound and picture problems. If used to record, at times the copy would would have no sound, at times it would have sound. Picture quality was always coarse and grainy. Could not be trusted so was seldom used. Are they notorious for this or is there a fix?
    Problem Solver:
  • 6 Answers
Went to TVForum.com and got almost instant help.
Thanks anyway.
MR
Posted on Nov 10, 2008
I'm trying to copy a tv show from my DVR and the recorder keeps saying Recording Error This program is not recordable in +vr mode. What is +vr mode?
Recording mode is set wrong, change it and try again unless there is an anti-copy signal on recording which some money hungry cable companies do to screw with customers.
Sep 01, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
I'm using a coax cable from symphonic vr-701 to tv and trying to record. it acts like it is recording but just shows snowy image on playback
Coax from wall to coax in on VCR and Vcr Coax out to in on set.
Whatever channel vcr is on this way it will record and pass to set.
Check first you have playback from VCR to TV alone, could have dirty or blocked video heads which in record will just record no watchable picture. Hookup or blocked video heads are most likely.
Dec 13, 2012 | Symphonic Televison & Video
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Magnavox H2160MW9 VHS tape "recording not allowed" to hard drive
RIAA has prodded the electronics manufacturers into putting copy protection into their recorders. You are allowed one copy, I believe, and you will be able to make it to a DVD-R in VR mode. VR mode protects (how? dunno) the recording from being copied a second time. DVD-RAM and DVD-R (maybe -RW) in VR mode should allow you to make your copy.
RIAA - Recording Industry Association of America
tom
Jan 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Samsung DVD-VR 375 records but sometimes I get only sound
Some program have copy protection or your installations cable and setup try to set lower resolutions and make sure you see the picture on TV before record
Or tell me how are your installation from which device to where
I may able to help you
Cheers
Dec 09, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
I have a Samsung DVD -VR 357 combo unit and i can't record
I have the Samsung dvd-vr 357. I have had a couple problems with it but I called samsung and they walked me through fixing it each time. I don't know if you have tried this or not but that is my suggestion. The last problem I had was copying from vcr to dvd. I got audio but no video. Problem was it was on dvd when i started it, it should have been on vrc. It should be set on whichever one you are recording from. Hope this helps someone.
Nov 12, 2008 | Samsung DVD-VR357
Samsung DVD VR355 DVD format problems
I have just copied a video to a dvd on my samsung dvd-vr355 and finialised the disc with a title now it will not play any disc,even if it is. shop bought, just says loading then the dvd opens to reject the disc. please help
Mar 07, 2008 | Televison & Video
Can't make copies of DVD's recorded on Samsung DVD-VR330
This is a common problem with DVD recorders. To make the answer simple, we could say that they construct a rather corrupt table of contents and the corrupt table of contents leads software through a tangled map through the video files.
They record in a format that is either DVD-VR or DVD+VR and that is a bit different from the easily copyable DVD-Video format. And, as I said, they often corrupt the format a bit in the process.
There are many software solutions out there. I hate to recommend one because they all have their quirks and strengths.
My best suggestion is for you to go to: http://www.videohelp.com. The topic you've presented has been addressed hundreds of times in those forums. Just browse some of the threads and you'll discover some of the popular methods for easily copying the discs your Samsung has been churning out.
It won't cost you a dime for the freeware solutions. You'll just have to use your brain a bit. Or, I'm sure that for about $50, you can get a one-click no-brainer. Just choose according to your budget.
Good luck. It will be easy. Those forums will let you assess the various approaches in great detail and they will give you step-by-step solutions.
Jan 15, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Televison & Video Logo
Henry  Thomas
Henry Thomas
