Question about Panasonic Televison & Video
Hi, My Panasonic DMR EX768EB all of a sudden started to randomly stop recording and gives the error message on the machine as "NoRec". Can't see anything in troubleshooting to suggest why!. Any thoughts on what the problem might be?? Thanks in advance D
SOURCE: Panasonic DMR-ES10 DVD Recorder.
Posted on Dec 17, 2007
SOURCE: Panasonic DVD recorder DMR-EX77 -
It's actually a fault on the device that needs to be repaired.
Posted on Jul 16, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
  • 50 Answers
Here is the english manual..
Use a pdf reader to open the file..
Posted on May 30, 2009
  • 17 Answers
SOURCE: Problem with Panasonic DVD Recorder DMR-ES15
With a soft cloth, clean the 'hole' area of a DVD that you know worked in the past. Sometimes oils from our fingers get on the disc and then the disk can't spin properly. If the problem persists, open the case and look for two failed capacitors. (See similar solutions on this website.)
Posted on Sep 09, 2009
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Panasonic DMR-E80H "u99" error message?
It sounds like the HDD is finished, it could not recover, you could see if a computer repair store can help, they have the tools and the software to take it further, but I would consider cost for the attempt.
Apr 02, 2012 | Panasonic DMR-E80H DVD Recorder
I have a Panasonic DVD recorder with hard drive (DMR-EX769). EVERY time I switch it on the following message pops up on screen : "A new DVB channel has been found. Start DVB Auto-Setup? Selective...
I believe there is an option to stop that. It's just finding out on what menu it is on. Some Panasonic machines have it on the FUNCTION MENU then press SETUP then press DIGITAL TV TUNING. It's often listed as NEW CHANNEL MESSAGE.
Selecting that will switch it off or at least the options for it.
It's probably caused by weak stations that get detected then drop out again.
Jun 16, 2017 | Panasonic Televison & Video
I've had a Panasonic DMR-E85H since 2005 and it's always worked great. Several weeks ago when I pushed the button on the romote to start the machine, it went through the normal startup & self-test then...
My E85H went totally out the other day. Had been experiencing the dreaded 'please wait' syndrome for the past month but started working again. I e-mailed Panasonic and they told me to send it to;
McAllen Service Center
4900 George McVay Dr.
Suite B Door #12
McAllen, Tx 78503
Said it would take 2 - 3 weeks, include a note explaining the issue. They do not need the power cord or remote. Also said charges would $50+parts+shipping. I assume labor will be higher after they determine what the problem is.
Have you looked at this thread I followed the well written advice/instructions, took mine apart tonight and found 3 bad capacitors which I will be replacing tomorrow. If I have the luck that the others have reported my unit should be up and running tomorrow night for under $10 and a little time. Hope this helps.
Mar 14, 2010 | Panasonic DMR-E85H DVD Recorder
Since it went into "disk recovery mode" it now will not play dvds
Got the same problem. Happened 2 months after guarantee expired. **** machine. The only good thing is the harddrive and that is made by HITACHI not Panasonic! I go Sony next time. Panasonic quoted £200 plus to fix the problem. I only paid £220 when I bought it new.
Sep 13, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Any1 know how to unlock Panasonic DMR-EX768EB to multi region??
Get an unlock device DMR-EX768 (never mind the EB) from www.genuinecopies and follow the instructions. On the handset the red square in the bottom row is the STOP/EJECT
Feb 14, 2009 | Onkyo DV-CP704 DVD Player
Panasonic ES40v - Can't play DVD's - Incorrect region
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
Nov 02, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR E55 DVD Recorder
Hi James,
When in EXT link mode the recorder is looking for a signal from the TV to start recording off the TV's timers system.
There is a EXT Link button on the remote control and pressing that will take the machine back to normal mode. The button is near the bottom of the remote.
Hope this helps
Sep 09, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Televison & Video Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
