Will only pickup one half of the bobbin thread when zigzag stitches. I have treaded it several times, cleaned and oiled bobbin chamber and tried different bobbins
SOURCE: Picking up the bobbin thread
A few suggestions:
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
SOURCE: my singer athena 2000 won't
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
SOURCE: back side of fabric stitch is not smooth
This is caused by inadequate tension on the top thread make sure there are no broken threads between the discs of your upper tension and it should be set on app #4
SOURCE: Juki HZL-E61: cannot get tension right on straight stitch
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
SOURCE: Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
This was a new machine, returned it!! Thanks
