Question about Microsoft Windows XP Home Edition
Install power quest with vista
Is it possible to install powerquest partionmagic with windows vita
  • 488 Answers
No,its not recommended..use this..
hope it helps!
Posted on Nov 08, 2008
Is the ensoniq mr61 compatible with windows 8? Is there a device or upgrade for this?
Supported Operating Systems and Hardware MQ Essen
Info 32-bit Windows support: Win 8, Win 7, Vista, XP checkyes.png checkyes.png checkyes.png 64-bit Windows support: Win 8 x64, Win 7 x64, Vista x64, XP x64 checkyes.png checkyes.png checkyes.png Windows Midi Quest x64 with x64 plug-ins to support 64-bit VST hosts checkyes.png Intel Macintosh systems: OS X 10.9, 10.8, 10.7, 10.6 and 10.5
Check this link
May 29, 2014 | Computers & Internet
Converting my wd my book essential 1.5tb/to from nfts to fat32 so my ps3 will read it to play movies
You can achieve this in Windows "Control panel -> administrative tools-> computer management->disk management". Make sure your USB drive is connected and swiched on. You will see the drive on the right of your screen at the bottom of the other drives you have. Select the partion you want to change/delete and from "actions" choose "all tasks->format-> FAT 32". you may have to delete the partition, so that windows will allow the formatting. I ahve jsut done this with my WD 1TB drive.
Mar 31, 2010 | Computers & Internet
Corel 8 will not install in vita ..why?
Try installing in Administrator Mode.
Jan 29, 2010 | Corel Draw 8
How to install windows vita without cd rom
u need either have it on ur in a multipartetion Hard disk....i.e. ur HD must be logical partition in the foll way:
to install in C drive u must have the Vista install files in D or E...
else u can have the Vista intsall files in a USB drive or pen drive and ur BIOS must be reset to boot from USB device...
Jan 13, 2010 | Computers & Internet
Blank white screen
Try right clicking the shortcut and choose "Run as Administrator". If that doesn't work, post back.
Jun 03, 2009 | Got Game Atlantis Quest for Windows
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Some Canon devices may not be Vista compatible and cannot work on Vista.
Aug 02, 2008 | Canon MVX460 Mini DV Digital Camcorder
Cannot run Fujifilm Software for FinePix with Windows Vista
1) If you right-click on the executable file, can you use the
"Compatibility" TAB to run it as an XP program?
2) Many XP device drivers will fail to install or execute properly
under windows VISTA, and I suspect it is the camera's USB
or Fire-wire (IEEE-1394) based device driver that is causing
the problem, not the main application.
Unfortunately there is NO easy solution for this,
except to get an upgraded software package (for Vista)
from the Camera Manufacturer.
3) There are also two possible work-around(s), but both require
some knowledge and software installation:
Install both Windows XP and Windows Vista on your
computer using two separate hard-drive partitions, and
a boot manager.
A partitioning tool like "Norton Partition Magic", formerly
"Power Quest" or "Acronis Tools" can be used to partition
the hard-drive non-distructively (your data is preserved):
a) Resize (shrink) the existing Windows partition.
b) Create a new partition for Windows XP (about 10 Gigs)
c) Install Windows XP-Pro onto the new partition,
d) Add both the XP and Vista partitions to the BOOT.INI
file on the boot drive.
Both windows XP and Vista do have multi-boot capability,
but the Windows XP boot manager may not recognize Vista,
in which case you may have to re-install or re-pair the Vista
installation. The Vista boot manager will recognize WinXP.
Running VISTA is generally a bad idea, because it is obscenely
slow and inefficient compared to XP, and because it is infected
Microsof't draconian and arrogant copy protection schemes,
known as DRM = Digital Rights Management.
Towards this end, Vista also insists that all installed multi-media
devices must be "Recording Industry" compliant and approved,
to make music and movie piracy more difficult. Many media
copying programs and CD-rippers will also refuse to run,
by design.
All this "Added Technology" is stealing your money, your
computer resources, your performance, and your right to
backup your media, at your expense, for the benefit of
the movie industry Mafia.
Use Vista only when you have to, boot to Windows XP for
most of your applications.
Both Microsoft and VM-ware (as well as others) make
a software product called a Virtual-PC, which allows you
to emulate multiple operating systems under windows,
including older windows, MAC and Linux.
VMWare is by far the best, the most reliable and the
most flexible, at about $200 US.
May 07, 2008 | Computers & Internet
[English Below]
No lo encontrarás.
Utiliza el mismo para Windows XP, cuando lo instales presiona "Continue Anyway" (o su equivalente en Español). Esto debe funcionar, hasta la fecha Vista aún no tiene soporte para tu modelo de Canon.
The question is: "I cannot find the controller for a Canon BJC-250 Printer for Windows Vista"
CoolDragon's Answer:
You won't find it.
Use the same one for Windows XP, when you install it press "continue anyway" until today, Vista has no support for that model of Canon printer.
Jan 24, 2008 | Canon BJC 250 X. Files InkJet Printer
I do not create harddisk partition
Then start again i wont work unless you do?
Sep 30, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition Logo
229 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
