Question about Maytag PAV2300 Top Load Washer
Agitator keeps falling off
The agitator keeps falling off. I have to screw it back down before every load. I'm thinking the bolt is stripped, but it looks fine. I'm hoping that I don't have to replace the entire thing. No one else seems to have this exact problem since I can't find it anywhere. Any suggestions?
    Problem Solver:
  • 6 Answers
Put a little blue loctite on it.
Posted on Feb 28, 2007
How do you take the agitator apart to get to the screw on a GE mod WBSR3140DAWW washer
simply reach under the base of the whole agitator and pull upward,it may take some considerable pulling for it to release,then theres a 7/16" bolt to remove the agitator spline
May 11, 2012 | General Electric WBSR3140GWW Top Load...
Won't agitat under agitator yellow coupling held by 7/16 bolt should this spin freely or does this mean its stripped
it probably means that it's stripped. it grips the spine and allows movement of the agitator. the transmission shaft may be rotating back and forth, but the agitator doesnt move properly. i would remove the coupling and take a look underneath it to see if it's stripped.
Jul 06, 2011 | GE WBSR3140DW Top Load Washer
Agitator loose does not swish clothes around .... can't figure out how to remove the agitator in order to see what may have come loosened or if splines are stripped .... how do you remove the agitator ?
Hello, on the style GE washer there is an agitator coupling under the agitator that will sometimes strip out. To repair this remove the agitator by pulling it straight up and out.
TIP: If you can't get your fingers under the agitator, you can slip a belt under the agitator and then pull by that, once the agitator is off you should see a yellow coupling held on by a 7/16 bolt, remove that bolt and pull the coupling up and off the transmission shaft. Sometimes it will be hard to remove and you might need to knock it up with a hammer. Once it is off you should be able to slide the new one back on, bolt it down and push the agitator back on.
Thanks
Jun 14, 2010 | GE WBSR3140DW Top Load Washer
Whirlpool top-loader LSQ9200LQ0 The top half of the agitator is not turning. I am assuming it is a stripped part. What would be the best way to take this apart??
You have what bad "agitator dogs". Yes this is a stripped out part. To get to the dogs, you will need to take the fabric softener dispenser off the top of the agitator (if your unit does not have a dispenser, then just take the cover of the agitator). Under that you will see a semi transparent cap that fits inside the shaft of the agitator, pull that straight up and out of the agitator. Now you can see the bolt that hold the agitator to the transmission shaft, this is a 1/2" or 9/16" bolt. You will need a socket with a long extension to reach this. Take a digital picture, or sketch the position of the dogs inside the agitator, this will help with the reassembly process. Once the bolt is out, the agitator will lift off. Turn the agitator upside down and depress the tabs up inside the shaft of the agitator, this will release the top of the agitator from the bottom, be careful, there are small parts that will fall out. Try to separate it in one piece, as this will make it easier to reassemble. Once separated, remove the old dogs and replace with the new, reassemble in reverse. When tightening the bolt, only tighten snug, the black rubber gasket should not bulge out when tightened. Also make sure the "o" ring on the semi transparent cover is in place and not broken. If you have questions, write me back. Hope this helps!
Dec 14, 2009 | Whirlpool LXR9445JT Top Load Washer
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 | Dryers
Not agitating
does it have the dual agitator
Aug 06, 2009 | Amana NTW5205TQ Top Load Washer
Top loading kitchen aid washer that shakes down the house
probably wouldnt look under hte agitator for problem. although the trick is to hold t he agitator while loosening hte bolt, it will then lifts right off after bolt removed., i would remove hte cover and perhaps look for a broken spring , bleach sometimes falls through rusting out metal brackets
Dec 05, 2008 | KitchenAid KAWS850L Top Load Washer
Agitator gear is stripped
just place both feet on the agitator as it sits on the floor and lift up on the top half. there are plastic tabs on the bottom half that hold the two pieces together. you will need to remove the 2 tabs before putting the 2 pieces together. the bolt that you screw the agitator down with will hold the 2 pieces together. Joe
Dec 03, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Loose agitator on Whirlpool Ultima Care II washer
it could have stripped the spline on the plastic agitator. there is a bolt at the middle of the agitator and you can access that thru the top . remove the top cover and you can remove the bolt using a deep socket.
once you remove the agitator you can look at the dog agitator. these a 4 pcs plastics that works like a one way wrench.
be careful on the location, they are very hard to put back.
check also the spline on the inner part of the plastic assembly.
they do get stripped.
if they are, replace the whole agitator.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Washing Machines
Agitator fall off and knocking noise during spin cycle
there should be a rubber washer with the bolt. if it is missing the bolt may back of during agitation. also the threads on the transimision may be stripped. Some Green lock tight found in most hard ware stores should help. the knocking noise is probably due the agitator coming loose.
Sep 16, 2007 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
120 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
