Question about Sony Handycam DCR-TRV27 Mini DV Digital Camcorder
My Sony MiniDV TRV27
Hi
I have a Sony DCR-TRV27 with which I am facing a problem. A part of the left side console buttons do not work - the tape controls (REW, FF, STOP, PAUSE, PLAY) work alright. The Memory Stick controls seem to work alright. But, pressing the Menu button does not bring any menu display on the screen. Similarly, the scrolling wheel on the front seems not working. A couple of years back the moisture went inside (I went to Niagara falls!). For few weeks whole of the panel wasn't working but now most of it works. But I cannot get the Menu option work. Could you please advise. If you need any other information please feel free to ask. I would be glad to hear if you have any other suggestions. thanks for your time,
  • aanov7 Nov 30, 2008
    Thank you mistersony for your helpful comments. I am going to venture to open and clean it myself. I need little more help - which side should I open (keeping the camera straight when the lens is on the far side and on/off switch is on the right). Couple of days back the tape controls have been working. The wheel control (that switches the menu) on the front doesn't work. I am sure going to try doing it myself, pls help. tia
  • 320 Answers
The moisture that got inside has probably begun to corrode the connections to the control panel. Your best solution is to get the camcorder to a qualified technician and get it cleaned (the circuit boards cleaned) as soon as possible. If you want to try opening up the unit yourself (I don't recommend this because the units are fragile inside and easy to damage) you will be looking for the ribbon cable and the connector where the control panel connects to the main board. You will likely see either a white crystalline substance or perhaps a black substance on the connector or the ribbon cable (this is the corrosion ) which you can clean off with a toothbrush and perhaps some Caig Labs R5 (available from Amazon, a type of contact cleaner). Be sure to rate this solution. Thanks!
Posted on Nov 08, 2008
Hi! my sony dcr-trv265e can play the tapes via the video and tv but when i re-record over them its just a blank blank screen? so i need anothe tape or can i record over old tapes?
Sony and the other media suppliers do not recommend re-recording over any digital tapes, including MiniDV. Re using tapes can lead to dropouts and errors after only a few times. With MiniDV prices so inexpensive these days (in the grand scheme of things), is there any reason NOT to use new tape? Also, many companies keep all their MiniDV tapes as a kind of stock footage archive. You never know when you might need a shot that you have already filmed, and it saves considerable time and money to pick the tape off the shelf.
Mar 13, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Oct 17, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
I JUST BOUGHT A USED SONY HANDYCAM DCR-TRV27 MINI
Congratulations! Please use the following link to download Manual, Operation Guide and other things.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRTRV27
Aug 14, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Copying home made video from sony Hi8 tapes to Sony DV mini tapes
Sony DCR-HC21 has a multi-AV in, your Hi-8 should have a mini (4 band) to multi AV out. The cable would look like a stereo headphone cable on one end with thre RDA type plugs on the other end; red, white, yellow. The mulit in on the DV would probabaly be the same type connector. Youd have to use a coupler set for the two multi-av cables to bridge video to video and audio to audio. Come out of the Hi8 into the miniDV recorder. You should not need a Dazzle unless you want to transfer to a PC for editing before moving video back to a miniDV tape.
Jul 26, 2009 | Sony DSR-30 Mini DV VCR
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
Jun 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Hi....
The dcr-hc38 is a minidv camcorder that usea a minidv tape. There is no "delete" on tape camcorders. You simply record over the tape. Or if you want to get rid of a recorded section on the tape you dont want, find out the exact minutes/seconds display of the section you dont want and just record over the section with the lens cap on.  To fully edit the tape, you will need to upload to your computer and use the editing software that came with your camcorder.
Jun 12, 2009 | Sony DCR-HC38 Mini DV Digital Camcorder
Sony DCR PC9E - Handy Cam - Nothing is functioning: Here What I did. I was trying to eject the MiniDV, the ejected miniDV struck in between while ejecting, then I presssed the reset button of the camera,...
hold reset with batt on cam. then place on wall charger. back and forth till it ejects tape fully. if this doesnt work flat rate to send in usually is about 250
May 31, 2009 | Sony Handycam DCR-PC9E Mini DV Digital...
Is the memory stick of sony handy cam minidv trv-18 expandable?
On many cameras , the picture format that you can save on memory stick is not the same that you can have by recording on tapes. It should be tha same on your handycam.
You can increase memory stick to at least 2GB, that is what sony reccomends, you can test a 4 gb to 16 gb at the shop, if it works , then buy it.
However, the quality of movies grabbed on memory stick, should be far less than the one of movies recorded on tape.
Oct 15, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
Sony DCR-TRV27
i have (or probably had) the same problem. Try this - there is a small reset button on the left side panel of the camcorder. While the set is on VCR model press this and keep pressed for 30 seconds or so. The corrected image should return and probably the problem would go away. I tried this by chance and the problem doesn't seem to recur.
good luck.
I have another problem though:
In my Sony DCR-TRV27 - A part of the left side console buttons do not work - the tape controls (REW, FF, STOP, PAUSE, PLAY) work alright. The Memory Stick controls seem to work alright. But, pressing the Menu button does not bring any menu display on the screen. Similarly, the scrolling wheel on the front seems not working. A couple of years back the moisture went inside (I went to Niagara falls!). For few weeks whole of the panel wasn't working but now most of it works. But I cannot get the Menu option work. I would be glad to hear if you have any other suggestions / advises. thanks for your time,
Nov 06, 2007 | Sony Handycam DCR-TRV27 Mini DV Digital...
Sony Handycam DCR-TRV27 Mini DV Digital Camcorder Logo
85 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
