Question about IBM ThinkPad T40 2373 Notebook
ECC Error on IBM T40
Got it today on my T40. Ran diagnostics after machine stopped working. Disk-read error ctrl alt del to reboot it said. Of course my backup is obsolete, and all my family photos and stuff will be gone.
Is there anu utility or something that can fix the problem?
Back in the old days when I worked with computers, we har Norton utility, that could fix allmost any hw-problem, but now I'm stuck.....
Pls help.
Dag (Norway)
  • Dag_Norway Dec 07, 2008
    Takk Ståle (Thanx),
    I borrowed that kind of a converter, but it seemed the cluster errors were so serious that it was not possible to read any data from the disk...
    Thanks anyway !
    Problem Solver:
  • 14 Answers
Hi Dag!
It could be either a faulty contact (unscrew the screw and try to re-seat the harddrive) or a one or more cluster errors on your harddrive. In that case, remove the harddrive, get yourself a 40-pin IDE-to-USB-converter like this one http://www.netshop.no/aspx/produkt/prdinfovnet.aspx?plid=103475.
This one will do the trick with support for S ATA, IDE (40pin 2.5") and IDE (44pin 3.5").
Then just connect it to another computer and save the files and photos you need into that computer.
Best wishes
Ståle
Posted on Dec 07, 2008
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Disk read error alt+ctrl del restart
load optimal or fail save setting then check if it eliminates the problem if it didn't work. reinstall the ide cable of your hard disk check if it eliminates the problem if it also didn't work back up your hard drive for important file, delete and create hard disk file system, partition and reformat your hard drive if this also didnt work replace your hard disk.
Sep 14, 2009 | Microsoft Windows® XP Professional Full...
Inspiron 1521 won't boot up. Get read disk error.
hello!!
put ur OS cd and enter repair console and try fixboot command!!!
Mar 23, 2009 | Dell Inspiron 1521 Notebook
SATA HDD not working
Avinash thaks for providing the exact error..
Re: A Disk Read Error Occured. Press CTRL ALT DEL to restart
1 - Have you tried a different IDE cable?
If not give it a go and do a repair if needed again!
2 - You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
3 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
4 - or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!! Good Luck D.i.l.i.p
Jul 02, 2008 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Error Message Upon booting up
go to bios and load defaults. if still same thing happens after reboot. Boot from OS cd, on windows etup page, choose "R" to run recovery console. Choose OS. Run CHKDSK /R.
Feb 16, 2008 | Compaq Evo N610C Notebook
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
IBM ThinkPad T40 2373 Notebook Logo
279 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
