Question about Canon PIXMA IP5200 InkJet Photo Printer
Print head problem
When i turn it on it gives me an error message
5 yellow blinks that leads to printhead.
    Guru:
  • Canon Expert
  • 183 Answers
Dear palia1234,
Blinking in orange 5 times indicates that the printhead error occurs. You need to replace the printhead with a new one. But be careful before replacing the printhead, check your printhead if any smoke smell or indication of short circuitry present. Replacing the printhead in this case will harm new printhead. You'd better to take your printer to the nearest service center.
Regards,
Source:
Canon Inkjet Printer Forum
Posted on Nov 22, 2008
Error: print head is installed not correctly & yellow light is blinking 5 times(Error E5). Normal print head is installed from other same printer but the error is still on. How to reset it?
This cannot be reset, tricked, or buffaloed .
The print heads have a built in device that makes sure you cannot swap out the part from another printer and install it other than he printer it originally it was installed in.
Part no. is:
QY6-0072-000 Printhead for CANON Pixma IP4600 IP4700
I hope this helps, Steve
Aug 16, 2015 | Canon PIXMA iP4700 InkJet Photo Printer
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
I am getting message "the
More black/yellow print head failure we observed in this series, no remidy for this issue replace the print head..
Sep 23, 2011 | HP Officejet Pro L7680 All-In-One Printer
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove all ink tanks
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
What does the third light from the left indicate? I have no manual and can't print one to find out. The blinking just started and now printer will not print at all in any mode.
From the left - Light 1 is ink cartridge, (color indicates which ink) Light 2 is Print head, light 3 is configuration, 4 is cancel, 5 is resume , 6 is power.
Probably it's out of yellow ink.
Here's the HP page for your printer : http://h10025.www1.hp.com/ewfrf/wc/product?product=2511753&lc=en&cc=ca&dlc=en&submit.y=0&submit.x=0&lang=en&cc=ca
The manual is here : http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=ca&lang=en&product=2511753&
Oct 25, 2009 | HP OfficeJet Pro K5400dn Photo Printer
Print head error message
reset it in window printing menu. perhaps it works.
Dec 03, 2008 | HP Business InkJet 2800 Printer
The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Oct 31, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printhead
sounds like a cable is off or broken.
Apr 10, 2008 | HP Officejet 9110 All-In-One InkJet...
Canon PIXMA IP5200 InkJet Photo Printer Logo
520 people viewed this question
old marine
old marine
