My headphone sockit stopt working on my computer, and i am not sure how to fix it
    Problem Solver:
  • 7 Answers
Is it still showing in device manager?
Posted on Nov 08, 2008
Why is the sound in one ear only?
It's probably a broken wire.
First, make sure it happens with those headphones no matter what you plug them into. If you're using them on your computer, try plugging them into your phone or someone else's computer. If you're using the quarter-inch adapter, try plugging into something that will take the eight-inch plug (the picture I'm seeing of your headphones shows an eighth-inch plug with a quarter-inch adapter). If the problems goes away, then it's either the adapter or the audio jack on the original device. But a new quarter-inch adapter online or at your local Radio Shack. If that doesn't fix it, then the jack on your device is shot, and your best bet is probably to get a new device. (Before I spent the money on a new device, I'd borrow another set of headphones, just to be sure that the problem persists no matter what headphones you use.) If the device is a computer, then you can buy a USB sound card (which plugs into a USB port and has mike and headphone jacks on the other end) instead of replacing the whole computer.
But it's more likely that the problem will persist no matter what you plug into, and it's your headphones. It's probably a broken wire; sometimes if you jiggle the wires going into the dead earpiece, you'll get crackling to confirm this diagnosis. But it doesn't really matter why the headphones don't work; no matter what's broken, the repair is more expensive than replacement. Time for new headphones.
The above answer assumes that you are listening to a stereo sound source. In addition to trying your headphones on another device, you should make sure you're listening to a stereo sound.
Mar 02, 2015 | JVC HA-V570 Full-Size DJ Headphones With...
Skullcandy repair centre
restore using the utility system restore go to control panel, and put the last day that you know was working good.
However you can use cleaner contacts solvent and fix it. Open in control panel the icon sound and use the tabs for headphone, and test the troubleshooting.
You mus sure that you headphone is good, try to test in another computer or CD, DVD. etc
God bless you
Jul 17, 2013 | Computers & Internet
A8n32-sli stopt na 10 seconden
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
Jun 03, 2012 | ASUS Computers & Internet
Dell inspiron 1525 not getting any sound out of headphone jack...I have 2 headphone jacks on the front of my computer. The right one has always worked when I plug headphones or sound cord in. Today, I...
The jack might need replacement since it may be broken on the inside. Also check with your headphones on anther known working device to make sure that the issue is not with the headset.
Sep 03, 2017 | Dell Inspiron 1525 Laptop Computer PC...
My DT-770 headphones work when plugged into my computer, but when plugged into my Presonus Firewire Studio with 1/4" plug, only the left headphone works. Any ideas on how to fix this? I use them...
Make sure the 1/4" plug you are using is a TRS connector, which has 3 separate partitions on the terminal plug. This looks like the following connector:
If you are using a Stereo TRS connector with your headphones, and it is an adapter, make sure the input of the adapter is also stereo, and not a mono 1/8" to stereo 1/4" adapter.
Else, you may have a bad terminal or corroded/dirty terminal on your Firewire Studio.
Jul 04, 2011 | Beyerdynamic DT 770 PRO Professional...
Dell D810 speakers do not work, but headphone jack does work
It seems as though you might have a bad plug, There is a set of tabs that tell the laptop whether to use the speakers or the headphones. This switch may of locked into the headphones position. This is probably a case of where you would need to replace or repair the headphones port. check to make sure there is nothing in the port to block it. You can also try applying some light oil on the end of a headphones jack and placing it in and out several times to break free a possible stuck part. It also may be a case that the solder mark on the board has disconnected itself from the headphones jack and needs reseating. This would be a difficult fix but not at all impossible.
Apr 26, 2010 | Dell Latitude D810 PC Notebook
Can someone help pls my hp dv6000 fan stopt working the one above the proccecer and i dint notice this untill i turnd it on and melted a wee bit off the plastic above the fan becouse of the heat strain...
dirt **** and old age is the reason for fan failer
replace the fan then turn on the computer again make sure if the fan has 3 wires you replace it with a 3 wire as it monitors fan speed
Jul 25, 2009 | Computers & Internet
How to know this is p4 motherboard in diagram
ummm check the sockit numer and then googl it, i think P4s are sockit 775, oh and if the apple mobo is g5 or earlyer its not a p4 that i know of, hope it helps
Jun 11, 2009 | Apple Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
