Question about Gigabyte GA-8I915G Pro Motherboard
Motherboard related hi ! my self umeshpatel and i have problem with my motherbord its still not working .. it is power on but it does not give display .. i change my smps,powecable,processor,ram,all asemble unit i cheked with my other working pc and they are all working.. and yeah beep sound also not comming form my motherboard.. my motherbord is Intel 81915G ..
  • 461 Answers
Take your motherboard for repair or buy a new motherboard... you may want to check below link to read more about technical issue that might related to your problem
Good Luck!!
Posted on Nov 08, 2008
No display of my motherbord
The problem is that the enable jumper for the onboard video is not installed.
Note: The POST beep should be occurring, to indicate there is nothing wrong with the motherboard.
If the motherboard onboard video is bad, install a graphics card.
Aug 24, 2015 | ASUS Computers & Internet
Yedterday i re assembled my pc i have a probleam with internal connection like (front panel usb,restart button shutdown button ,hdd light, power light)my motherboard model number is intel d946gzis...
Related wiring to the front panel trace their origin and look for the pins related in the front of the motherboard. Match power button wires to the PSU or motherbord interface plugs.
Aug 24, 2010 | Intel D946GZIS Motherboard
Power supply
If a power supply ends up in smoke, this usually is just bad luck (may of course be related to a bad design of the power supply or use of low quality components).
As for the BIOS settings: If you were messing around with certain overclocking settings (or are not sure if someone else did), it may be a good idea to use the "Reset to defaults" option. However, wrong BIOS settings rather may have an effect on the lifetime of motherboard and CPU but not on the power supply.
Just make sure that you use a power supply of sufficient wattage: 300W or 350W for a standard PC, somewhat more if you have a high end graphics card or many hard drives / optical drives.
Apr 03, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Hp compaq d530 motherboard is not responding,what do i do?
hi, try replacing the battery of the motherboard for it may be worn, a faulty battery usually makes the board not to work or sluggish. hope this helps
Feb 19, 2010 | HP Compaq Motherboard
Computer wont turn on
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Nov 21, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Asus motherboard( A7N266-VM)
FOr reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defaults.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Nov 11, 2009 | ASUS A7N266-VM Motherboard
I am having the computer with Intel 845GVSR motherboard,P4 Processor,1 gb RAM Configuration. When i switch on the system, three beep sounds come and the system is not booting. But the RAM is in working...
For that first open cpu cabinet then refix RAM memory try it in defferent slot on motherbord.
Pull cmos cell from motherbord for 10 minutes so all settings goes to defaults.
Then open processor fan and processor then refix both.
Reconnect ATX power connector to motherbord.
Reconnect power cable and sata or ide cable to harddisk.
If any PCI cards are installed then remove it from pci clot then check.
Make sure your motherbord is not ground with cabinet check in outside of cabinet .
Nov 10, 2009 | Intel D845GVSR Motherboard
HP Pavilion DV2000 no Display
First pull motherbord from cabinet some times motherboard is grounding with cabienet.
Then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reconnect ATX power connector to motherboard.
Then check.
If still same issue then open processor fan and processor then clean dust from all place in mothebord.
Then try.
If you still got same then something rong with your ram or motherbord.
Change ram then try.
Pull all card from PCI slot check motherbord only with RAM not even harddisk and other device.
Let me know if you need more assistanse.
Aug 31, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Motherbord is not giving display
change the power supply and try agine
Apr 06, 2009 | Computers & Internet
Motherboard problem
Hi get the motherboard and power supply checked .
May 24, 2008 | Computers & Internet
Gigabyte GA-8I915G Pro Motherboard Logo
82 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
