No power whatsoever going to my sky box after a 12 hour power cut. Can you help
    Brigadier General:
  • 6,966 Answers
Initially, would suggest checking for a blown fuse at the rear or inside the Sky box. Your description of "no power whatsoever" indicates that the mains is not reaching the internal power supply/regulator of the box. Of course, it would also help to try the unit in another outlet.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
The date and day are incorrect on my dakota atomic watch; how do I reset these please ?
if just time is off by one to three hour(s) , you need to ck your time zone settings , if the day is off by one day you need to wait 24hrs keeping watch in a good view of the sky (not locked in a metal box) it should auto correct itself to proper day when it receives the radio signal for two time cycles (24hrs)
Dec 13, 2016 | Dakota Watches
I have reheated sky go but it won't let me on I have sky multy room but it won't let me watch sky
disconnect all leads going to your sky box and leave off for 10--15 minutes then with power unplugged reconnect all other cables then connect power cable and turn on sky box if this does not work contact sky for a service call.
Nov 02, 2014 | Televison & Video
Sky +not connecting
Do a hard reset &/ update will solve most problem, It will take about 10min. How to unplug the box, plug in but keep pressing backup button. release the button when all led light up and shows "Updating System Software" message. Thus done.
Oct 21, 2013 | Computers & Internet
2nd tv will not find signal after electric power cut
usually a surge like that can damage the circuitry
Jul 21, 2012 | Televison & Video
Where can I find an online copy of the Sky+HD box "User Guide" please
Click the following link or cut and paste it into your browser:-
http://www.sky.com/helpcentre/export/sites/www.sky.com/helpcentre/tv/anytime-plus/__Content/hd_manual.pdf_1314843347.pdf
I've assumed you're asking about the regular Sky+ HD box and not the Sky+ HD 1TB box, if I'm wrong then use the next link:-
http://www.sky.com/helpcentre/export/sites/www.sky.com/helpcentre/tv/anytime-plus/__Content/1TB_Manual.pdf_1314843347.pdf
I hope that my free answer has been prompt and helpful, if so then please take a brief moment to rate my reply.
Mar 07, 2011 | Televison & Video
Sky plus is playing up on our set up. It will not let us access the recorded programmes for long periods at a time it can take up to half an hour to get it to play sometimes we give up cos it just isn't...
hello it sound like it need a software up date here is what to do unplug the power lead at the back of the sky box .on the front of the sky box is a button called backup. press hold the backup button while doing this plug the power lead back in you should get a message saying do not disconnect the the power
regards
shaun
May 19, 2010 | Televison & Video
The hd tv keeps cutting out and saying no signal
It not the tv,u restart the Sky HD box the signal come back right?The Sky HD box is the problems,replaced the box,u will solved this problems.
Apr 22, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I have just had a skyhd box fitted and every time i switch my technika tv off and then switch it back on i am getting a blank purple screen .it is as if the tv is not reconising the hdmi input cable .the...
I have the same problem, i just bought a new Samsung 37" and am getting the "Purple Screen" on occasion when i switch from Blu-Ray back to Sky HD. I didnt have this issue with my older Samsung. Upon looking into this i have discovered that it is to do with the HDMI Handshake between the TV and Sky Box. One solution i have read is to buy a HDMI splitter that is HDCP compliant (ALL SHOULD BE IN THIS COUNTRY) what happens then is that Sky does the handshake with the splitter and all is ok. I cant confirm that this works as i have not had chance to try it, but it all adds up and makes sense. Hope this helps
Dec 01, 2009 | Televison & Video
Premier sub used to work great ... now nothing
Did you check to make sure that you didn't blow a channel in the amp? Another thing to check would be the connection on the inside of your box, maybe there is just a wire loose.
Dec 19, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
