Question about Malber WD1000 Front Load Washer/Dryer
Snap-on spigot coupling won't stay connected
We connect our Malber to the sink, when we use it, with a hose couplling that snaps onto an adapter supplied with the machine. It worked fine when we got the machine, for a couple of months or so, but then started popping off the adapter. Malber supplied us (no charge) with a new adapter, which solved the problem for another couple of months, but then the same thing again. The coupling passes water at any pressure so long as the washer is taking in water, but as soon as the intake shuts off, the back pressure forces the hose coupling to pop off the adapter. It can't be recoupled unless the water is turned off at the tap, or until the washer is ready for water intake again. We've tried reducing the water flow, but the coupling won't stay on unless the flow is reduced to an irregular trickle that takes forever to fill the washer for a wash or rinse. If anyone has experience with this problem and has found a solution, we'd like to know. Many thanks in advance, Michael "Tiesenhausen"
  • Michael Bates Jan 09, 2008
    Apprentice is absolutely correct. It finally came to me a couple of months ago, out of the blue, that the coupling is a standard hardware item. We bought a new one at Home Depot for about $3.00 and have not had any problems since then. If the hose starts popping off again, we'll just buy a new coupling.
    I'm really pleased that someone responded to my inquiry. And it only took 2 years and 2 months! I should have written myself to let others know, but I had forgotten that I submitted the question.
    Thank you very much, Apprentice.
    Michael
    Problem Solver:
  • 13 Answers
Sounds like too much water pressure or, more likely, the coupler has worn down. You can get a replacement at most hrdware stores.
Posted on Jan 08, 2008
Where is the sink spigot located ? I have a fault #20 showing on the dial
That will be the drain hose connection to the sink drain pipe probably under the sink. Google sink spigot in images and you can see what it looks like. I take it it is blocked..
Jun 15, 2014 | AEG 23 in. Favorit 50750Vi Built-in...
My newly installed dishwasher won't drain, what could be the cause?
If the dishwasher is connected to a spigot on the waste under the sink, check that the end has been cut off the spigot (on the plumbing not the machine hose) or that end stoppers have been removed. Also, check the hose has not been crushed when installed.
Mar 04, 2013 | Bosch SHE3AR52UC Builtin Dishwasher
Leaking washing machine faucet adapter
fit the rubber washer into the adaptor that seals off on the tap face
can be obtained from any garden tap fitting
Jan 24, 2018 | Washing Machines
How do i unhook the spigot from my undersink reverse osmosis system i cant get the hose connections to release so that i can take the spigot off the sink. i am putting in a new sink
If they are quick connect fittings make sure all the water pressure is off the lines. Turn off the RO tank and valve feeding system, open the faucet and try taking lines off again. If no luck, mark the lines with masking tape and cut them a couple inches below faucet to remove.
RJ
Oct 24, 2010 | Culligan Under Sink Water Filter
Plastic hose disconnect Frigidaire dishwasher - sink side
Most dishwashers connect to the garbage disposal and just have that barbed connection that it clamps onto with a hose clamp, unless that actual connector itself broke off (which wouldn't be pressure related, that would mean someone hit something against it breakin it) You should be able to just use a screwedriver and tighten the hose with the clamp back onto the garbage disposal.
If the plastic connector did break off then you will have to buy a new garbage disposal and replace the whole thing. Which is just a little heavy and time consuming but not all that difficult to do.
Or if it did break off, and your handy with glue, then you could try using a waterproof glue to glue it back on?
Also just a warning, if you try to use the sink, make sure you have a bucket underneath the garbage disposal as water will then leak out the hole where the dishwasher drainage tube was connected until you get it fixed.
Jul 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
How To Connect Sinks Drain
No matter what type of sink you purchase, the drain and water-supply connections are generally installed in the same way. Hand-tighten a female adapter onto the drain stub-out at the wall. Slide slip nuts onto the drain arm and the sink's tailpiece. Fit a P-trap in place and tighten the slip nuts by hand. Connect flexible water-supply tubes onto the faucet's tailpieces, and route them to the shut-off valves. Tighten coupling nuts with an adjustable wrench. Remove the faucet aerator, turn on the water, check for leaks at the shutoff valves, and then turn on the faucet to check for leaks in the drain assembly. Replace the aerator.
Aug 27, 2008 | Blanco 510-879 Single Bowl Undermount...
Dishwasher takes too long
first thing to check is the connection from the drain hose to the spigot under the sink. in most cases food accumulates there because the hole inside the spigot in not drilled all the way around when the d/w is installed and a "lip" is left where the food stacks onto. if clear check for a kink in the drain hose at the back of the d/w and all the way to the sink. if ok then time to check the drain pump.
take care.
Jul 22, 2008 | Siemens Dishwashers
LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
May 11, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Download detects networks
Usually when this happens the antenna wire connections have come dislodged. Did you put this in recently? Has the laptop been dropped? The internal antenna wires snap onto this type of internal wireless card and not always snap on secure. THat would be the 1st thing to check.
Mar 31, 2008 | Broadcom BCM94306MP - IEEE 802.11b/g...
Connect my D-snap SD Camera to a compatible PC with the USB cable
Make sure both the Battery Pack and AC Adapter are connected to the D-snap SD Camera when connected to a compatible PC.
Aug 31, 2005 | Panasonic D-Snap SV-AS30 Digital Camera
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
151 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
