Question about Toshiba Tecra 8200 Notebook
My Tecra 8200 will not power up,not to monitor,hard disk,cd rom please advise right course
My laptop doesn't power up ie. monitor doesn't come on, hard disk doesn't come on and it does power up in a friends laptop cd rom doesn't power up, the indicator lights come on when i have the power supply connected,for pwr. supply symbol and charging the batt. the indicator light to show you that you turn the laptop on even lights up none of the above items power up. I bought this laptop used and would like to know if this is abig problem and try to get my money back or fix what ever the problem is, maybe it's something pretty simple,that would be nice.
  • 2 more comments
  • blgxbadxbam Dec 08, 2008
    i am having the EXACT same problem
  • nickwho Dec 19, 2008
    Tecra 8200 stated to stop mouse to move arrow on screen. soon after ownt start up after battery power lights show.
    any ideas? regards edward
  • josh_mcwhomp Mar 06, 2009
    my laptop shows the lights that charge the battery and what not but it just will not turn on do i press the little battery where that little sliding switch is or what?
  • ch_luke99 Mar 07, 2009
    no power on start up, led lights just blink, nothing else works. No fan, DVD drive, notta. what can i do? Thanks
When I unplug my Toshiba Tecra 8200 with windows XP, the screen becomes dark, but not too dark. Please help!
Check your power setting preferences - although I am not familiar with your computer, some laptops reduce power to the processor and screen when unplugged to save battery power. You can normally change the settings so that it runs normally whether plugged in or on battery (although of course the battery will then not last as long)
Mar 30, 2010 | Toshiba Tecra 8200 Notebook
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
Need to down load system disk for tecra 8200
I would suggest using a recovery disk, but if you need the data off of it I would take it to the a repair shop.
You can get a recovery disk here.
http://www.recovery-cds.com/laptop/search.asp?keywords=toshiba
Feb 24, 2009 | Toshiba Tecra 8200 PT820U-OFG8C801...
Toshiba tecra will not boot up
Your motherboard is the issue here I have seen this problem many times but just to make sure try hooking it to an external monitor
Dec 08, 2008 | Toshiba Tecra 8200 Notebook
Disck error
Generally the hard drive, not the motherboard.
Aug 12, 2008 | Toshiba Tecra 8200 Notebook
Hard disk Problem
dont repair it do the full system format
May 19, 2008 | Toshiba Satellite A105 Notebook
Dell inspiron 8200
Check your BIOS make sure your HDD and CD-ROMs are enable I did the same thing and found i had been laying to much in BIOS
Oct 13, 2007 | Sharp Dell Inspiron 8200 15.0 ASV UXGA -...
Toshiba Tecra 8200 Notebook Logo
284 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
