My administrator tools have shut down,how do i get them back please
  • 13,433 Answers
Please use the add a comment button to explain what do you exactly mean with administrator tools?
press start -> run -> type in mmc  now you got the management console open and you can add the snap in there?
Posted on Nov 08, 2008
  • Ekse Nov 08, 2008
    start -> run -> compmgmt.msc opens the computer management
System manager has been shut down and won't start. it keepa going from the vaio screen to the windows xp screen over and over then displaying message system manager has been shut down........HELP PLEASE ...
try starting up in safe mode and if you can you can go into administrative tools and reset your defaults.
right when you start it up press f8 a few times until you get boot options then click safe mode.
Sep 29, 2013 | Sony VAIO Computers & Internet
Please wait while windows configures adobe acrobat 7.1.0 professional. error 1324 the path adobe cs is invalid please enter it again i have unistalled cs but still get this error code when ever i open up...
HI, Open up the Control Panel. Open Administrative Tools. Open Computer Management On the left, click on Disk Management. Right-click on the drive you want to change the drive letter of and select ?Change Drive Letter and Paths?? Change the drive letter to the one you want it to be. (Make sure no other drives currently use the letter you want.) Shut down your computer, then power back up. TNKS RABBANEES
Nov 11, 2009 | Computers & Internet
Spooling problem will not clear. I have shut down computer twice and followed directions thru the administrative tools
Please follow the link to fix this problem http://support.microsoft.com/kb/324757 and run the microsoft fix it and restart the print spooler service from services.
or follow the link
http://support.microsoft.com/kb/2000007
and restart the computer.
or you can run both of them fix it.
Oct 30, 2009 | Brother HL 2140 Laser Printer
What do you mean by this error? "The instruction at 0x003bfc61 refferd memory at 0x305eff8 the memory could not be written".
most likely it is a software error, as the pc is shutting all of the running programs down to turn off the PC, that is where the error comes in, you could try to stop some of the background programs to try to figure out exactly what app it is refering to. It will probably not harm anything unless it is a program like word or something and you haven't saved the document, if that can't be written before the PC shuts down, you would lose your work. If it is a memory issue with the actual RAM, you can run a memory test in windows under all programs Administrative Tools, or in the control panel under Administative Tools, and then Memory Diagnostics, to check the hardware,
Please give a fixya if this helps or solves your problem
May 15, 2009 | Computers & Internet
Printer utility says off-line
try turn your printer off and back on and see whaat happen
Mar 21, 2009 | HP Photosmart 3210 All-In-One InkJet...
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box.
    If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
Password
go to microsoft.com and get the password recovery program for Windows XP.
If that doesn't work, get the computer into safe mode by shutting down the computer, turn it back on. At the beginning of the boot process press f8 and select safe mode. Select the Administrator if its available and go into the Administrative tools in windows. Select users. Delete the user. Create new user. I've never tried this in safe mode before but if you can't get admini privilages in safe mode you could be dead in the water.
If that doesn't work, you will have to reinstall windows.
Jun 14, 2008 | Microsoft Windows XP Professional With...
Shut down services
If you are using Windows XP, follow these steps.
Open your Control Panel, click "Performance and Maintenance", and then go to "Administrative Tools". Go to "Local Security Policy".
Under 'Security Settings' -> 'Local Policies' -> 'Security Options', find "Shutdown: Allow System to be shut down without having to log on" and enable it.
That should take care of it.
Apr 09, 2008 | Microsoft Windows Server Standard 2003 for...
Hp printer
ok...first thing...go to www.hp.com and download a fresh set of drivers for your printer, and then restart it and see if that helps. I have that happen to my G85 whenever the power gets awful(not saying that's your reason, but can be an issue)..
got backup?
Feb 15, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Shut down problem
if it gives you 60 secs warning , abort the shutdown by ---- shutdown /a---- command....and check for any servivice termination from administrative tools > services... check if all the automatic strted services are running
Jan 26, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
David Payne
David Payne
