Question about Sony CFD-E75 Cassette/CD Boombox
The tuner not working
Whenever I try to change the station, the numbers change but the station playing doesn't change. Anyway to reset the control on this.
  • rlaw212431 Sep 07, 2008
    changing tuner channels does not work for either FM or AM. Always receiving the same channel with background noise/hiss. Have replaced C batteries with new ones, but no improvement
    President:
  • 3,130 Answers
First thing to try would be to take out all of the batteries, including the clock battery if there is one. Wait 12 to 24 hours and reinstall the batteries. If that does not work, then there is a problem between the microprocessor and the varactor tuner inside this radio, and unless its less then one year old ,for warranty repair, it most like would not be worth the diagnosis charge or repair charge. Good Luck PS please do not forget to rate this thread
Posted on Oct 20, 2006
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
Alpine 9886 with sirius interface
This problem sounds very sirius. Sorry, couldn't resist, but "siriusly", the song alert feature is supposed to be something you select yourself, so it locates a particular song whenever it is played on the service. Do you recall setting this?
Are you using the Alpine KCA-SC100 tuner or another?
I would try resetting the radio too.
Dec 13, 2013 | Alpine Car Audio & Video
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
How to change tuner to pick up all frequence's eg: goes from 95.5 to 95.7 how do i get it to change to 95.6 thanks jason
It will only tune into odd numbered stations because US radio station only broadcast in odd number stations (ex 95.5,95.7,96.3). You can change the area. Area 1 is North America, Area 2 is other areas. Press "Menu"->"Setup"->"Tuner"->"Tuner Area", then select 1 or 2. After setting, press and hold "Menu" for at least 2 seconds. This may give you the frequency you are looking for.
Apr 14, 2011 | Alpine CDA-9855 CD Player
Tuner not working.
These do on occasion have a bad fm tuner assembly. part number 9630145608. to verify try a fm ant to see if works
Dec 09, 2009 | Denon AVR-1908
LXI tuner not working
Unfortunately without the make and model, there is little that we can do to assist you. There are too many tuner designs to be able to give you any useful information. Please try the unit in mono mode and with any "muting" turned off. If you receive stations with the muting and stereo modes turned off, the problem is with an I.F. amp stage. If you receive nothing, that is informative as well.
Please investigate a bit more and post the make and model and I should be able to assist.
Thanks,
Dan
Mar 13, 2009 | Audio Players & Recorders
Tuner seems to go out of tune after it plays for about 5-10 minutes
if you have soldering iron ,solder the rf coils ,this colis many cases have poor soldring wich will off tune agc.therefore you notice channels off tuned.
Oct 19, 2007 | RCA RS2664 Shelf System
I need reset pin number
To reset your pin on your base station, you push Menu, scroll to System Settings, DON'T PUSH SELECT, push * 6 5 # That will reset the pin.
Aug 17, 2007 | Siemens Gigaset 8825 Cordless Phone
Sony CFD-E75 Cassette/CD Boombox Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
