Question about Canon PIXMA iP1500 InkJet Photo Printer
Canon pixma iP 1000
My printer cannot print the problem is "The waste ink absorber is full". any solution? Thank You
  • 2 more comments
  • deriahmad Nov 08, 2008
    Printer still blinking green and orange. Anyway thank for you help. TQ
  • paulinaaprai Nov 15, 2008
    me dice que los residuos de tintas estan llenos y no imprime pero fueron limpiados que hacer para borrar la advertencia
  • rossand Nov 17, 2008
    the printer clicks over then when it should print it stops
  • Tony Hazel Nov 28, 2008
    I have/had the same problem with my iP1500 and the cure has worked , many thanks.
    Tony
    Brigadier General:
  • 6,966 Answers
The correct procedure calls for a replacement of the waste ink absorber. A bypass/temporary workaround is to reset the waste ink counter by:
  • Disconnect printer from AC power
  • Press and HOLD the POWER button, and connect printer to AC power
  • release the the POWER button
  • Press the POWER button again
If that does not work, pls try:
  • Turn off the printer, and disconnect the printer cable
  • Press and hold the POWER button, turn on the printer
  • The Indicator (LED) should be green
  • Press and release the RESUME button, the Indicator (LED) should be orange
  • Press and release the RESUME button again, the Indicator (LED) should be green
  • Release both button
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
My canon printer 1p 1000 says the waste ink absorber is full contact service center
hi
you need to replace the absorber waste container. But to ensure you can work around this, do this first. Remove the square rubber at the end of the right side of your printer. Use cotton cloth absorb the waste ink. Clean and wipe the ink around area and place the absorber back into the tray.
Finally clean your print head by using dry cotton swab. If this deosnt work, try this: if it doesnt solve the issue, you must replace absorber waste ink tank .
  • You can manually override it, but I recommend getting it replaced.
    Reset waste ink tank counter CANON PIXMA iP 1000
please send me 4 thumbs up
Jul 20, 2011 | Office Equipment & Supplies
Computer says"Waste ink absorber is
What is the make and model of your printer (I'm guessing it is a Canon?)
May 06, 2008 | Office Equipment & Supplies
A window displays inktank full and the printing is cancelled, when i give the print command ? what sould i do? when showed to an expert ,he told i need to update the firmware. Is this the solution ,if yes...
I suggest a window display "Waste Ink Absorber Full" or "Ink Tank Absorber Full" . It has to be reset.
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
If that not work just write on kernel84@abv.bg , and i send you a software to reset your printer.
Jan 18, 2011 | Canon PIXMA iP1000
Full ink absorber
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
WASTE INK ABSORBER IS FULL FOR CANON PIXMA iP2000
The machine needs to be taken in for the waste ink absorber to be replaced
Oct 03, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon printer mp160 e27
how can i get my ink absorber to be unful and work agian so i can print again WANALI
Aug 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Question for canon pixma iP 1000
folow these steps to reset it..
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
Nov 02, 2007 | Office Equipment & Supplies
Canon ip 1000 waste ink reset
want the software tool to reset the waste ink level for canon inkjet printers
Apr 20, 2006 | HP LaserJet 1020 Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
83 people viewed this question
old marine
old marine
