Question about Kodak EasyShare Thermal Photo Printer
Ink film wrapped round roller
I did not tighten the print ink carrier before inserting it and it has wrapped itself around the roller so the paper will not feed
    Genius:
  • 1,447 Answers
Hi
Unplugged and try to access inside of the printer, be extra careful because you might damge the sensors. If its hard to get the film around. have it service instead.
Hope this helps
Posted on Nov 08, 2008
Uneven wear on printer feed roller
Are they printing heavy card stock or envelopes? It seems they might be using a specialty paper or there may be hair wrapped around the other rollers somewhere too.
One possible solution is to get the next model year rollers and see if they fit If the manufacturer noted the problem they may have fixed it but are unwilling to acknowledge it publically on the newer models.
Nov 07, 2013 | HP LaserJet Office Equipment & Supplies
Black ink printing on back of paper
Your paper feed rollers have some black ink contamination: wipe the rollers, all around, with slightly moist tissue paper until there are no more ink evidence coming off the rollers. To moisten tissue, warm water with a very small amount of Windex, dish soap or rubbing alcohol does wonder.
Also clean gently around the bottom of the print head assembly to remove any obvious splatters.
Hope i helps.
Sep 26, 2011 | Canon PIXMA® MP530 All-In-One Printer
My printer is printing blurry on the right hand third of the page - the rest is crystal clear
The printer's head with the ink cartridges runs on a rail above the paper path. The paper comes out face down so the left side of the printer prints the right side of the page. The bottom of the print cartridge is either too close or too far away from the paper. So look for something that is lifting the paper up like some paper wrapped around the rollers or something that would move the head up or down like a loose rail - it would be on the left side of the printer. If it is not paper or some other foreign material on the rollers or stuffed behind them (open the rear cover plate too), the chances are that it will not be cost effective to service the printer.
Nov 11, 2010 | HP DeskJet 810c InkJet Printer
Ink smudging off paper
It means that the fuser is not hot enough to bond the toner to the paper. You should open the rear door and see if a paper has wrapped around the fuser roller, as when the temp is actually too cool it will shut down the printer. Photo paper is also too thick to be used in this printer and you should only be using standard bond paper.
Feb 22, 2010 | Minolta magicolor 2400W Laser Printer
Paper rolling up with the thermal film
The best thing you can do, short of launching the thing into inter-galactic travel, is to clean all of the plastic parts of the machine with an anti-static cleaner. Particularly, the roller that feeds the paper and the carbon roll. Remove all paper and carbon film and unplug the machine. Clean inside the paper housing and the feed rollers before turning it back on. It sounds like a build up of static electricity, a common problem on such thermal based fax machines. Remember, the paper has the propensity to curl because it is on a roll, so any extra help it gets will send it curling like mad. Good Luck.
Jul 20, 2009 | Panasonic KX-FP141E Plain Paper Thermal...
Dell 944 carrier jam
THE CARRIER MAY HAVE A FINE PEACE OF PAPER STUCK IN THE FEEDER ROLLER OR IN THE ROLLER PANS, REMOVE EVERYTHING, GET A CAN OF AIR AND BLOW IT OUT GOOD AROUND WHERE THE PAPER FEED AND EXITS THE PRINTER, THE CARTRIDGE MAY MAYBE GETTING SNAGED ON THE PRINT HEAD ALSO. SHACK THE PRINTER UPSIDE DOWN TO GET ANY TYPE OF MATTERAIL IN THE MACHINE, IT CAN BE PAPER, PAPER CLIP, STAPLE, PENCIL, ERASER MATTERAIL,
INK BUILD UP ON THE ROLLERS, CHANGE THE TYPE OF PAPER YOU ARE USING, IT MIGHT BE CHEAP PAPER PRODUCTS, LABEL GUM STUCK INSIDE THE PRINTER HOUSING AND EVERY TIME YOU USE IT JAMS.
ROD
Feb 13, 2009 | Dell 944 All-In-One InkJet Printer
New ink roll in Philips fax Magic 2
Have just tec support (10p per min robbers !!)
Here is what you do
OPEN MACHINE
WITH THE NEW INK FILM IN, ROLL THE INK FILM ON ROLLER NEAREST TO YOU FORWARD UNTIL ALL THE SILVER STRIPS TO THE RIGHT ARE NO LONGER VISIBLE (THIS IS THE BAR CODE ON THE INK ROLL IT'S SELF)
REMOVE INK FILM FROM MACHINE
CLOSE MACHINE
TYPE IN OK 45 OK 7117 OK (THEN IT WILL ASK IF YOU ARE SURE) YES (CHANGE WITH < > BUTTONS BETWEEN OK BUTTON )
SET TIME AND DATE
OK
OPEN MACHINE
PUT INK FILM BACK IN
CLOSE MACHINE
YOUR DONE LOVERLY JUBBERLY !!!
HOPE THIS HELPS AS IT DROVE ME MAD Rob
Apr 04, 2008 | Philips PPF-531 Plain Paper Thermal...
Easyshare printer dock seris 3
TRY THIS
UNPLUG POWER CORD/USB TO COMPUTER IN BACK OF DOCK.TAKE OUT PAPER TRAY.
LIFT DOCK (LOOK INSIDE (DEEP INSIDE AND SEE IF YOU SEE THE CARTRIDGE FILM ON A STEEL ROLLER,WRAPPED AROUND IT.)A FLASHLIGHT MIGHT HELP IN THAT STEP).
IF CARTRIDGE IS WRAPPED AROUND TAKE TO SERVICE PROVIDER(I TRIED TO FIX IT LIKE THAT AND IT WAS A HASSEL)
IF NOT WRAPPED AROUND GO TO CARTRIDGE OPEN DOOR/LIFTGREEN TAB UP.SHOULD EJECT(IF NOT TRY A BUTTER KNIFE AND PRY UNDER SLIVER DOT)NOT HARD BUT WITH ALITTLE FORCE SHOULD POP OUT.
REMEMBER TO LIFT GREEN TAB WHILE PRYING.
IF STILL STUCK MAY BE STUCK IN PRINT MODE
THATS BEYOND ME. GOOD LUCK.
Mar 19, 2008 | Kodak EasyShare Thermal Photo Printer
Kodak EasyShare Thermal Photo Printer Logo
59 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
