Question about Dell E176FP 17" LCD Monitor
Monitor When I am using my computer, all of a sudden the monitor goes into this blackout screen and then starts flashing repeatedly.... The big blue "DELL" in blue flashes in the middle of the computer with website name under it. After about a minute the monitor stops flashing, and I am able to continue where I was. This happens about every 10 minutes, all day long, and I am not sure what to do, or what is wrong with the monitor.
  • Dell Master
  • 1,183 Answers
Unplug the monitor from the back of the computer and keep it powered on . If the problem is encountered again. Try reseting the monitor . If the same does not help you need to replace the monitor.
Additional help can be found in the following link.
http://support.dell.com/support/edocs/monitors/1706FPSF/EN/solve.htm#General%20Problems
Posted on Mar 23, 2008
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
Dell E173FP Screen blinking red, green, blue, white
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 16, 2009 | Dell E173FP 17" LCD Monitor
Intermittent monitor blackout
if you check key board caps lock or num lock keys, also on aond off (LED in Caps and num lock)
you have check the video card , pls go to safe mode and test the problem
also need the check monitor with another pc
Sep 12, 2017 | Dell UltraSharp 1703FP Flat panel TFT 17"...
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E176FP 17" LCD Monitor Logo
224 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
