Question about Canon Photography
I do not know how to set date on my Canon IXUS 111 camera purchase date 17.05.05
Please can you give me instructions for the above camera
    Novelist:
  • 208 Answers
THIS ONE WAS A REAL PAIN! THEY HAD IT WELL HIDDEN, BUT I WAS ALBE TO LOCATE IT FOR YOU. THE FIRST THING YOU'RE GOING TO SEE IS A CANON SD600 AND GO WHAT???, BUT BELIEVE ME THIS IS ON THE RIGHT PAGE. ACCORDING TO CANON THIS IS THE PAGE AND INFO THEY USE TO ANSWER THIS PROBLEM BECAUSE IT FITS FOR MOST OF THEIR SYSTEMS! GO FIGURE! BUT THEY SAY THIS WILL WORK SO I'M PASSING THIS ALONG TO YOU IN GOOD FAITH AND HOPING LIKE HECK THAT IT DOES THE TRICK FOR YOU! THAT IS MY MAIN CONCERN, TO GET YOU BACK UP SHOOTING PHOTO'S AGAIN! I HAVE A VERY LONG HOT LINK FOR YOU THAT WILL TAKE YOU DIRECTLY TO THE MANUAL AND ON PAGE 16, YOU WILL FIND INFORMATION ON SETTING THE TIME AND THE DATE ON YOUR CAMERA. ALL I CAN SAY IS GOOD LUCK! AND IF IT DOES THE TRICK, DON'T FORGET TO VOTE ON THIS SOLUTION. THANKS! IF YOU NEED MORE HELP, REPLY TO ARCLIGHT1217.
http://www.ocad.ca/Assets/PDF_MEDIA/AV+$!26+Imaging+services/manuals/Canon+Powershot+SD-600+cam-Windows
THERE IT IS AND IT'S A BIG ONE AND I HOPE IT DOES THE TRICK FOR YOU! GOOD LUCK! REMEMBER, PAGE 16 AND IT STARTS OUT TALKING ABOUT USING THE CLOCK, BUT JUST READ THE FINE PRINT AND YOU'LL FIND THE DATE THROWN IN ALSO!
ARCLIGHT1217
Posted on Nov 13, 2008
  • BRIAN REISS
    BRIAN REISS Nov 13, 2008
    INSTRUCTIONS ARE ALL LISTED ABOVE IN THE TEXT. USE THEM EXACTLY.
    ARCLIGHT1217
How do iset date and time stamp on canon ixus 40
here you can find the manual for your product:
http://files.canon-europe.com/files/soft24168/Manual/IXUS30IXUS40_CUG_EN.pdf
if you go to page 76 of the manual, you'll find detailed instructions how to setup date stampo embedded in picture.
Let me know if this helped you, bye
May 04, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Tip
How to change / set time and date on Canon PowerShot SD1200 IS / 95 IS digital...
It is sometimes necessary to set the time or change the time on a digital camera.Some of the features on the camera actually require that you have set the time and date.To do this , follow the following steps.
  1. Firstly , Press the menu button
  2. Use the sideways arrow buttons to go to the settings tab indicated with a hammer and a wrench.
  3. Use the up and down arrow buttons to scroll to Time and Date and then press the function set button.
  4. Use the arrow buttons to select a area you would like to edit and use the up and down arrow buttons to select a time / date or value for a field.
  5. Once done , press the function set button again and the time and date will be saved.
For technical support from Canon , please follow either one of the following links to the support contact page. The steps descibed above are also included in the user manual which can be downloaded from Retrevo using the link below.
Canon USA
Canon Global
To download the manual for your camera , please click on the following link :
Where to find the manual (pdf) for Canon PowerShot 95 IS / SD1200 IS
Please rate this tip if you found it useful and please do not hesitate to contact me via the comments section if you would like more information or help in setting the time and date on you camera.
Kind Regards
StephanSA
on Mar 01, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
I have a cannon Ixus 75 digital camera, which I have had for several years, and cannot get the date to print on the photo's. I have set the date and time as instructed in the namual, but when I go to...
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again.
Dec 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon IXUS M-1 SET Compact Camera instructions need instruction booklet to operate time/ date etc...
Hello
OK, you will be able to download the manual at the link below.
Click HERE.
Let me know if you found this helpful.
Kind regards
Andrea
Sep 08, 2010 | Canon IXUS V2 Digital Camera
Date stamp
To set date stamp follow the instruction:-
1) Press MENU button. 2) Select REC Menu. 3) Use the up and down buttons to Select Date Stamp. 4) Toggle to the desired opetion OFF or ON.
Note:- Ensure the date & time is set before using date stamp function.
Good Luck
Mar 06, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How to set date stamp for canon ixus 860is
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
dsc_include_date01_tcm13-520510.jpgTo set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm13-520511.jpgBe aware that if you take pictures with this option enabled, the Date and Time cannot be removed from the pictures at a further time. It will permanently appear on the picture.
Please rate my help++++Thanks for using FIXYA
Feb 28, 2010 | Canon IXUS 860 IS Digital Camera
Taking the date off the pictures I take with my Canon Ixus 80 IS
Go to www.canonUSA.com, you can download the manual for the american version of the camera - the POWERSHOT SD 1100 IS
Instruction to turn on and off the date function are there.
Jan 20, 2010 | Canon IXUS 80 IS Digital Camera
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Push the function/set button. Press the directional button down to select Date and Time.
Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Feb 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I'M PLANNING TO BUY A CANON SD950 DO YOU THING BY BUYING A MEMORY EXTREME 111 4 GB IS GOOD?.
I have owned several Cannon brand cameras (not this particular model) and have always been very happy with them. I would support the purchase of any Cannon product.
cnet gives this camera a good review.
http://reviews.cnet.com/digital-cameras/canon-powershot-sd950-is/4505-6501_7-32591168.html
May 01, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Photography Logo
219 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
