Question about BenQ MP610 Multimedia Projector
Data projector model PB6100 menu button does not disppaly option
When a i press the menu option button on this project i get not menu option diplayed- any solutions i could investigate
    Problem Solver:
  • 6 Answers
U check button on the projector or cable could be the problem.Or change the cable inside thats all.ok..tq
Posted on Nov 25, 2008
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
My projector has only just over 200 hours and is now showing a replace lamp message. The hours have also been reset???
The lamp hours might have not been properly reset.
1. Press the "POWER" button so that the projector projects the picture on the wall (projection screen)
2. Press the "MENU" button to show the "MAIN MENU"
Use buttons "F" or "G" and select "OPTION"
3. Confirm this by pressing "ENTER" so that "OPTION" is shown
Using buttons "5 / 6", select "LAMP RUNTIME" (lamp operation counter)
4. Select and press the "ENTER" button for at least 3 seconds
5. The "LAMP RUNTIME" (lamp operation counter) will change to "TIME RESET[POWER OFF]"
6. Turn the device off by pressing "POWER" and unplug the power cord.
Aug 01, 2011 | Panasonic PT-F200NTU Projector
What i am projecting is cut off
Yes you can cut off you projection there is three ways to cut off.
1. there is a button on the projector name "SHUTTER" press the shutter to topping the projection temporary.
2. One same button on remote control "SHUTTER"
3. and the same function you can use with in menu of projector
press MENU button use LEFT and RIGHT arrow buttons to select "OPTION" press one time DOWN arrow button to select the SHUTTER press ENTER.
(for re-projection just press again SHUTTER button from remote control or projector key pad or through menu)
Jan 17, 2011 | Panasonic PT L735U Multimedia Projector
Reset hours on my dlp
hold exit button for 3 seconds until osd comes on for lamp timer. press menu, then left or right arrow button to set it to zero. then press exit.
Oct 24, 2009 | BenQ PB6100 Multimedia Projector
Can't access Menu
I have the same problem, any ideas to solve.Thankyou
Feb 22, 2009 | BenQ PB6100 Multimedia Projector
Blue-ish tint suddenly ?
the solution is as its follows: :)enter in
Factory Menu
1. How to enter factory menu:
2. Hold press "UP" button until the "Lamp hours info." OSD display on bottom-right of screen.
Press keypad <Power> and <Blank> key simultaneously again, then enter Factory menu.
enter in fan menu and increse the speed of fans. -> had to use the already written text...:P
3. with the keypad look for the menu that says <more options> on the bottom of the osd. once you are there go for the option HARD RESET.
4: also look for the option where its says SOFT RESET. its on other tab ... shut down the projector. take the power cord off the 6100. wait for about 10 seconds. plug it again and there you works again.!!
Oct 11, 2008 | BenQ PB6100 Multimedia Projector
Blue screen
Hi Guys,
I recently struck this issue with one of our PB6100's. To resolve I did the following:
  2. Under the Fan menu select "More Options". You should then be in the "Fac7 Submenu".
  3. Select "Hard Reset". Note that this will reset the lamp hours also!
  4. Power off & then on again. Test input.
The above worked for me. Hope it helps.
Jun 20, 2008 | BenQ PB6100 Multimedia Projector
PB6100:No picture display
The projector needs to be turned on first, then connect it to the laptop. If the picture still does not show at that point, press the FN and the LCD keys on your laptop at the same time. This should work.
Feb 10, 2008 | BenQ PB6100 Multimedia Projector
Pip position
Hi there
The PIP ( picture in picture ) is only to determine where the Menu block itself will show on your screen.
Try the Vertical and Horisontal shift in the Menu Options.
Oct 23, 2007 | BenQ PB6100 Multimedia Projector
Angle of projected image
Hi there
No this can not be changed , the PB6100 was actually designed to mounted upside down in your ceiling and therefore the lens is 28-30 degrees upwards when projected on a flat surface.
Flip it upside down and you'll see what I'm getting at.
Oct 07, 2007 | BenQ PB6100 Multimedia Projector
BenQ MP610 Multimedia Projector Logo
90 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
