Question about Pioneer CDJ-800 Turntable
Error message E-8302
After a few minutes of any CD, the cdj stops playing and E-8302 comes on the screen
  • Anonymous Nov 11, 2008
    brand new cdj 800mk II bought today first disc i put in, came up with the same error message but the same disc worked on the other cdj which is the same model
  • syoti0903 May 25, 2009
    my cdj800 error is the master tempo light is keep flashing at the first start it not the after an hour or two the master tempo light up or light off it blinks
  • 45 Answers
OPTIC LENS THAT READs DaTa From THE DIsK, OR THE GEARS ON THE MECHaNIsM, THaT MAY MEAN REPLACING THE WHOLE LOADING UNIT.
Posted on Aug 26, 2016
  • 68 Answers
Possible laser pick-up problem,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
Posted on Dec 03, 2008
  • 3 Answers
It sounds like you might have problems with your CDs. If you are burning CDs on your computer to play in the CDJ, you need to remember that it will only play audio (wav), or MP3 files. Also, blank data CDs are cheaper that buying audio / music CDs. When you burn your CDs to play back on the CDJ, you have to be sure to burn them as wav or mp3. AAC, MP4, OGG and the other formats will not work in the player. When you burn the CD, ALWAYS burn at a slower speed than what the computer will automatically burn at. You will have to manually set the speed yourself.
Personally- when i burn my tracks CDs for my CD book, I use trusted name brand blank data CDs such as Memorex, Sony, TDK, Fuji, Imation. I burn them as AUDIO ONLY. To avoid any reading mistakes that could happen with any given CD player, i NEVER burn track CDs as mp3. When i burn the CD, i set the writing speed to 24x, 30x, or 32x. I recommend that you DO NOT burn your CDs at any speed faster than 32x. From my experience, that is the fastest and safest burning speed. If you do these things, and you still have problems with the E-83 02 code, then it will only have to be the kind of CDs your using to burn, or your CD burner in your computer. Notice how i didn't mention Maxell CDs up top. 3 months ago, i bought 2 spindles of Maxell data blanks on sale for $9.99 each. I was happy i got them that cheap, but the CDs themselves were no good. Recording everything the way i do, they had popping noises and scratching sounds through-out the disc. I gave the spindles to my neighbor. He was happy to get blank CDs free. I WILL NOT say that Maxell makes a bad product: I still record on cassettes and Maxells are one of my top 3 choices for blank chrome tapes. But the discs i bought were just a bad batch. Maxell is still a trusted name for blank tapes with us older DJs that started out with recording on tapes before the CD format became way cheaper and affordable.
Try burning your discs as audio only, and burn them at 24x, 30x, or 32x ONLY. Buy better brand name data CDs, and you should have no problems. If you use my method as an example, and you still have problems, then you need to get a new CD burner for your computer. They are always cheaper at Staples or Office Depot. Hope **** works out for you : D
Posted on Nov 29, 2008
Eu tenho o cdj 100 s pionner que deu problema no leitor troquei os leitor uma funcionou e a outra não o que sera me ajude
hello frnd,
can u pls post ur complete problem. what error u get. does cds play or not. how old ur cdj's
thx
Aug 07, 2010 | Pioneer CDJ-100S CD Player
CDJ-1000 CD Player: SIR I HAVE 100S POINEER WHN I RUN CD I FACE ERROR ...
hi there,
you need to clean compartment of your cdj. Pls make sure if you can do it yourself then do it yourself or take it to an expert.
djajay
May 05, 2010 | Pioneer CDJ-1000 CD Player
Ejecting and error
Reading error. Problem with lents take to Pioneer service dealer
Aug 25, 2009 | Pioneer CDJ-100S CD Player
Cd error and ejecting
There is a problem with the motor that ejects the cd out!you start getting those error because you put mest up cds in your cdj!You need to always make sure there clean and not scrtch too bad specially with old cd decks like the 100!
When switching on the unit and loading a cd it can take a long while to register the cd then it will play for a few seconds then stop. this will clear after a few minutes and play as normal, however if i...
No this is not a common issue. If your traverse assembly is not damaged, then it's possible the loading motor might be the issue.
In either case, I would suggest professional assistance.
Hope this helps.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Jul 18, 2009 | Pioneer CDJ-800MK2 Turntable
Error - 8403 on cdj 200 not reed the cd
Can't find Error 8403 in the service manual. Please advise the correct error code and I'll see what I can find out for you.
E-7201 TOC READ ERROR 26: TOC data could not be read.
E-6002 DSP PROGRAM
DOWNLOAD ERROR
62: The program cannot be written in the DSP.
E-8301
PLAYER ERROR
(Startup error)
12: The desired address could not be searched.
15: Address data could not be read.
22: The Focus Servo could not be closed.
91: The pickup could not be returned to the inner track.
E-8302 PLAYER ERROR
(Abnormality in playback)
E-8303
PLAYER ERROR
(Abnormality in writing to the buffer)
99: Abnormality in writing in the buffer
E-8304
MP3 DECODE ERROR
(Abnormality in decoding)
Abnormality in decoding ∗∗
E-8305
DATA FORMAT ERROR
(Inappropriate data format)
A data format other than MP3 was used. ∗∗
E-9101 MECHANICAL TIME OUT 90: Abnormality in the disc-loading mechanism (TIMEOUT)
Feb 24, 2009 | Pioneer CDJ-1000 CD Player
CDJ 100 s PROBLEM E-9103 and E-7201
E-9103 is MECHANICAL TIME OUT,
Solution : some object in compartment slot, remove it, or clean player compartment
E-7201 is disc cant be read in 20 seconds,
Solution : Disc has scratch, Replace disc
Disc is dirty, Clean disc
Dj ajay
djajay@inbox.com
Feb 03, 2009 | Pioneer CDJ-100S CD Player
E-8302
This is a cd reader issue. More than likely it will need to be replaced. If your in the U.S., you can ship in your unit for repair by going here: Pioneer CDJ800 Repair
If your outside the U.S., you'll need to find an authorized Pioneer repair center to assist with this.
You can also just purchase the part, and bring it with you to the service shop for replacement.
Pioneer CDJ800 CD Reader
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Jan 21, 2009 | Pioneer CDJ-800 Turntable
My cdj mk2 screen wont light up or play
sounds like a power supply to lcd pcb is down, if you havent had it repaired you can send it to us.
Regards.
Aug 01, 2008 | Pioneer CDJ-1000 CD Player
No sound from CDJ-800 MK2
Are you getting error messages? Running in thru LINE? Is not on mute? The possiblity of both not playing would lead to process of elimination.
Keep me posted.
Oct 19, 2007 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800 Turntable Logo
2,742 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
