Kenwood KDC-X991 CD Player Logo
A
Anonymous Posted on Mar 26, 2012
Face plate saying protect
And no its not stolen. I have owned it for several years.just started doin it.
1 Related Answer
Anonymous
  • 624 Answers
  • Posted on Jul 25, 2008
SOURCE: power to stereo none to unit
There is a ribbon cable that goes from the display to the main board of the radio that may be bad, if you have everything connected properly and all you get is the red led, this is a possibility. No way for anybody to know if you have it wired wrong if they can not look at it themself.
The red wire is for power when the key is on, the yellow wire should get power all the time, the black wire is ground.
If you have those correct, the radio should at least turn on. If you have these right, you may need a new ribbon cable. The connector that interfaces with the detachable face must also be taken off the old ribbon cable and put on the new one, or get a new connector and just replace it. The ribbon cable does not come with that connector. It is soldered on the ribbon cable, so if you are not very good with a soldering iron, you should have a service center do it for you.
Let me know if you want the part number for the ribbon cable and/or connector, I can get those for you.
I can not guarantee that the ribbon cable is the problem, or that it is the only problem, but it is the most likely problem with that model number of Kenwood. I have repaired many of them, so I have a good idea what causes most of the problems, but I have seen times when the usual suspect is not the problem and something else like the LCD in the face is bad, or the IC that controls the display is bad. Even a voltage regulator on the main board of the radio can be at fault as well. There are probably about 10 different things that can cause that one problem, having an experienced technician is always the best way to determan the problem with certainty.
Let me know if I can be any more help for you.
Dave
1helpful
Face plate was stolen, can it be replaced by another planet audio face plate
no it has to be the same model face plate so it can insert correctly.
1helpful
I have a dual CD770 and every time i push the button to open the face plate,it wil start to open then immediatley close. how do i fix that? I own a 1997 Ford F150 Lariot EXT.CAB
You need to replace the ribbon cable that goes from location CN501 on the main board inside the unit to the face plate docking station. I have the had the same problem with mine for the last year and it finally broke. I just sent a quote request for the cable to dual.
NEED FACE FOR SONY MODEL CDX-RA700 CAR AUDIO
sony can provide you with a new face plate but depending on what type and what country your in there are laws that dont allow this as some times the units are stolen from cars there fore you might need to prove some how you own the unit ounce done you should be right
good luck
1helpful
Face Plate Was Stolen, Can I buy a new one?
yes from JVC unless the deck is more than 5 years old
3helpful
4answers
Face plate replacement
You can't find faceplates for card decks since that will defy the safety feature.
2helpful
4answers
Broken
face is damage u will need a new face plate i had the same problem. i have a working face plate for it $160
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
