Question about HP Office Equipment & Supplies
Printer works fine but when trying scanner,comes up with message'not connected to USB port"
    Genius:
  • 1,447 Answers
Hi-
Try to unplugged the USB cable from the back of your computer and printer then replug it.
Hope this helps
Posted on Nov 08, 2008
My Canon MP480 can print fine but when it comes to scanning it says, "Cannot communicate with scanner. Cable may be disconnected or scanner may be turnd off. Check status. Scanner driver will be...
I had the printer working fine till sometime, and then either a driver upgrade or a OS upgrade over time caused the scanner to stop working. Tried reinstalling the drivers to no avail. However, sticking a usb drive on the printer's usb port, as opposed to using a usb cable by-passes any issues with the drivers or the OS, and just worked great.
Aug 27, 2011 | Canon Pixma MP480 All-In-One InkJet...
""I can't get my scanner
If reinstalling the drivers doesn't work. Try manually adding the device.
1. Start>Control Panel
2. Under Hardware and Sound click, Add a device
3. From there you should see your Printer/scanner. Go thru the prompts and it should be able to find and install the drivers from manufacturer site
Mar 29, 2017 | Office Equipment & Supplies
Computer can't "see" scanner even though plugged into USB port
please check:
if other usb-devices work with your pc, so usb ports of your machine are ok.
try connecting the printer to another machine, using same procedure as u did with the old one
did you get any installation cd with it?
any newer drivers for your win-system available?( inet, manufacturers homepage)
if your system and the printer passed the hardware check, install newer drivers and try again.
wish u luck
Jun 18, 2009 | Ambir Technology DocketPort 485
Error message "Can not find camera.Please connect Omnivision SuperCam!" on my Vista laptop. Scanner works fine on my friend's XP desktop. Have tried all steps outlined in manual (several tim
On my Vista desktop it worked directly, but I had the same error message on my Vista laptop when the scanner was connected through an USB hub. Perhaps the power is not sufficient?
Then i plugged the connector directly into the laptop usb port 2.0, and the driver was automatically installed and works fine!
May 10, 2009 | Office Equipment & Supplies
The scanner(travelscan pro 600) gets a no power or not connected message!
Go to Device Manager and most likely the travelscan pro 600 is not popping up under imaging devices where it should be. Unplug the scanner and plug it into a different USB port. Try this on all the USB Ports on the machine if it reappears in device manager then the software will work. If you are using a USB extention cord or USB hub get rid of them till you try all the ports. If it doesn't i would suggest contacting the manufacture and seeing if the scanner is still under warranty.
Apr 17, 2009 | Ambir Technology TravelScan Pro 600
Mustek Scanexpress A3 USB scanner stopped working
my scanmagic 1200ub is recognized by my pc but i keep getting a message saying"cannot locate component.could it be that particular port?
Mar 29, 2009 | Mustek A3 USB Flatbed Scanner
My HP Laser jet 3055 has worked fine for a long time but now when I press "scan to" an error message pops up on the printer/scanner "not set up on pc". Nothing has changed and the...
Have you plugged in your printer into a different USB port on the computer? If so, return the USB cable to the original USB port it was in before. If not, try another USB port on the pc and have the driver disk handy because it might act like you have never had the printer plugged into the PC before.
Good luck
Nov 10, 2008 | HP Office Equipment & Supplies
Cannot communicate with scanner message
Try an get a USB 2.0 printer cable. Some of the Canon scanners will not communicate quick enough without one.
Nov 03, 2008 | Canon PIXMA MP150 All-In-One InkJet...
15 people viewed this question
Seeker5211
Seeker5211
