I have a LG a/c unit, model # LT1030HY5, the unit cools, but the heating function doesn't work. I want to know what part I may need to replace or if there are any trouble shooting tips
    Scholar:
  • 131 Answers
FIRST THING IS TO PULL THE UNIT OUT OF THE CASE,NOW ISOLATE THE HEAT STRIP BY DIS CONNECTING THE LEADS,NOW TAKE YOUR OHMMETER & CHECK FOR CONNTINUITY,I'M WILLING TO BET YOU GET INFINITE OHMS(WHICH MEANS YOU NEED TO REPLACE THE STRIP)IF NOT YOU HAVE A RELAY OR SWITCH PROBLEM.(LET ME KNOW)
Posted on Nov 08, 2008
Have a LG split air conditioner Model # LS243HLV getting error code CH 38
Please give model numbers of both indoor and outdoor units!
Aug 21, 2017 | LG Heating & Cooling
I have a LG air conditioner which seems stuck on defrost. It works fine in cooling but when on heat the defrost light comes.
Possibly a stuck or closed defrost sensor. The sensor gets to freezing which closes the switch. So the unit goes into defrost cycle which switches the flow of the freon on a Heatpump. The hot gas thaws the coil and the sensor. Which opens the switch and switches it back. I'm giving this answer without knowing more about the unit. Defrost light comes on & it doesn't run at all? LG system is a split unit or window unit or what?
Feb 19, 2017 | LG Heating & Cooling
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
The unit will not turn on after trying the pushing the power button. The green light on the reset button shows that it is on but on the display not lights are on. I tried to inplug and wait and plug the...
You need to bypass the on/off switch by jumping it, thereby taking the switch out of the circuit. If it works you have a bad switch. If it doesn't you have a power to the switch problem. Do you have a multimeter and a wiring diagram for this unit?
Aug 02, 2011 | LG Heating & Cooling
Window AC Model No. : LG LWA18G 2DF1AK42 IS THERE INBUILT HEATING FUNCTION? HOW TO USE?
Please try to understand with your model, the tonnage and also whether it's cool only or heat & cool. 12,000 (12)...........means 1 TR. with this help your a/c is 1.5 Tr and if it's heat and cool definately there wil be indication in the model cde it self. Ex.......A18TH DF..... like this. There will be H added in the model code itself. Yours is not heat mode. Is it helpful?
Dec 13, 2010 | Amana PTC094B35AM Air Conditioner
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
My LG 7000 BTU Heat / Cool Window Air Conditioner does not cool and the fan speed F1 will not work. Fan runs on F2. The heat works fine. Any suggestions?
You have a control board issue. You can get a new control board by Google searching the make and the model of the unit. There are several sites that sell them
May 24, 2010 | LG Heat cool Window Air Conditioner
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
