Ciss for the epson r285
The first time the printer told me there was no ink i turned off the printer still had the same problem but after a few attemps they did reset however the second time they have ran out i cant get it to reset i have tried turning it off and leaving it off but nothing has worked there is plenty of ink in the pots so it isnt that thank you
  • PARKSEY Nov 08, 2008
    That fixed the problem THANKS
  • 57 Answers
Hi parksey,
Try to do clean test,
pick up the in cartridge and clean connection tips and rrfit it.
hope this helpfull,
thanks
Hamedo
Posted on Nov 08, 2008
Epson 1390 red ink light remains on
we have a r1390 power on carries move laft or when carries home possion than red led balking same time
Aug 25, 2012 | Epson Stylus Office Equipment & Supplies
First time visitor. Entered Epson Stylus Photo R285 into search box. As I scrolled down what I presume is the result of my search, there were answers for everything BUT my R285. I use a CISS kit on my...
Welcome to FixYa.
This occurs when the ink pad counter times out and is supposed to be a dealer service to drain the waste reservoir and replace the pad.
The only thing that you can do is try to reset the printer. Please do the following:
  • Turn off the printer by pressing the power button. Check to make sure that the print head is in the default position, to the far right of the device and locked in place.
  • Hold down the paper feed button. Turn on the printer by pressing the power button.
  • Release the paper feed button as the paper feed light starts to flash. Immediately hold down the ink-drops button for 15 seconds.
  • Wait for the printer to complete its test run. Turn off the printer and then turn it back on once more.
Thank you for using Fixya, keep me posted.
Jas247
Aug 23, 2011 | Epson Stylus Photo InkJet Printer
Epson R285 need service utility
It sounds a lot like you have managed to reset the printer using the R290 adjustment utility and it now thinks that your printer is an R290 printer.
As a result it's rejecting the yellow cartridge (presumably the first to read empty since you reset the printer) and expects you to provide R290 consumables.
The only fix that I've heard suggested (and I'm still waiting to hear if it worked) if to get someone with a valid R285 to use the same adjustment utility to make a backup of the EEPROM data (nothing else), save this file, send it to you, and then for you to restore that same data to your own printer EEPROM.
As I said, I haven't heard if it works and I could be wrong about the cause but as I provide waste kits myself and have already had quite a few people report a similar issue I suspect I'm about right.
Hope that helps.
Martin
Jul 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Hi my epson r285 with ciss is leaving ink blotches all over my print outs, predominantly black, but less frequent with the other colours. This is only a new printer. Head cleaning, noxzzle cleaning and...
It might be caused by waste ink at bottom plate around head sprayer. For some CISS (bottle) design, ink will flow to head, and then flow to pad, when printer off. So, you must close respiratory hole at bottle when printer is not used. For cleaning, turn off printer (unplug power) when head is not in parking position. Move head to center. Put wet tissue (with cleaner or hot water) at top of pad (at head cleaning mechanics). Move head to parking position. So bottom plate contact with tissue. Wait for 10 minutes, repeat 3 times. Check nozzle.
Jun 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Why does everyone go quiet when I mention Epson r285 , 2 red flashing lights and service needed. Does no-one of you highly intelligent boffins know how to reset a simple printer. Ive asked and asked on...
Bit late in replying but this guide for dealing with the R285 has been up for a while now.
It tackles everything from installing a waste ink tank to resetting the waste ink counter.
Wrote the thing myself following quite a bit of interest... Hope it helps.
Apr 06, 2009 | Epson Stylus 2200 InkJet Photo Printer
2 red lights flashing service required
Hi there
All you need to do is to download SSC Service Utility from the net ( FREE ) install on to your computer and then follow the instructions to reset all counters and this should solve your problem.
Apr 06, 2009 | Epson Office Equipment & Supplies
press maintence power and the small ink button all at the same time this will reset the printer
Apr 05, 2009 | Epson Stylus 2200 InkJet Photo Printer
Ciss for epson r285 printer not reconising new system
Check the carts on the ciss the chip on the front will have the version number in the top left corner the latest version for all new R285 is I believe V5.0 if you have a version earlier than this you may have probs I believe its possible with a little care to buy some disposable compat carts and remove the chips and put them on your ciss carts this should solve the problem....Tel.
Oct 11, 2008 | Office Equipment & Supplies
83 people viewed this question
jasbo
jasbo
