Good Morning ,I have a Westherm thermostat fitted to the central heating radiators in my home.I have read the posts concerning freeing the centre pin and understand how to free this.After freeing the centre pin and refixing the head as supplied will the valve operate as before i.e the radiator valve can be turned on and off . Your help is appreciated. Best Regards Gerry Pritchard
After removing thermostat head apply minute drop of WD40 to centre pin and move gently replace thermo head and thermostat is working as new.
Posted on Nov 09, 2008
Cleaning inside central heating radiater
I'm assuming your saying you have hot water heat and you're having trouble with the broiler or stoppage in the pipes leading from the boiler to your wall radiators. Every household boiler I've seen has been very old and isn't worth replacing. If you decide to replace it, you will be replacing more than just the boiler. You'll be replacing many copper lines as well. The solution is usually changing to some alternative style heating such as electric baseboard with individual thermostats.
Jan 28, 2014 | Plumbing
Honeywell t100b1035 thermostatic radiator actuator fails to open, no heat coming out of radiator.
Keven
take the top of and u will see a pin sticking up this is jammed down u will need to free of using the Handel of a large screw driver hit the pin several times till it frees of it will jump up if this fails u will have to drain down and remove it fit a new one
Sep 17, 2013 | Honeywell T100B1035 Thermostatic Radiator...
What is the different between a direct and indirect meter
DIRECT HEAT METERING The direct metering is the most accurate and reliable system for measuring the amount of energy used by individual households for heating their homes. The solution is applicable only in heat systems with horizontal distribution pipes network or areas in which the heat transfer fluid is distributed to individual apartments or to industrial plants, by district heating or by an individual central unit servicing more buildings. The system is composed by a thermal energy meter, a motorized valve controlled by a programmable thermostat located inside the apartment, in this way the user can adjust the temperature of the household and determine the hours of heating being able to manage the system according to his specific needs. .
INDIRECT HEAT METERING The indirect metering is applied to the plants where the distribution of the heat transfer fluid is achieved through risers, which means that the pipes of fluid flowing through the radiators of the single apartments have more points adrift from the main system (risers) that feed the individual radiators, making it difficult to measure the flow rate of fluid that enters the apartment. For simplicity we use the example of a riser which feeds the radiator of a room and at the same time also the counterpart room located on the upper floor. In this case, the use of individual devices, defined as heat cost allocators, installed on each radiator within individual apartments allows to avoid the unfair solution for which heating costs are allocated in accordance with the size of the apartment. Based on the operating parameters of the radiator itself it is calculated, in an indirect way, the amount of heat that the radiator releases into the environment. The sum of the readings of all the radiators provides the total consumption of the apartment and, with all apartments equipped with devices set with homogeneous parameters, you can proceed with the allocation by individual apartment of the centralized system total heating costs.
Aug 24, 2013 | Professional Metering System
Overheating
Replace thermostat and radiator cup flush radiator with RF-505 flush run engine with no thermostat for 30 minutes than fit new thermostat check radiator hose top and bottom has to be even hot if still same then change the central unit for the fans .
Sep 12, 2012 | 1995 Chevrolet Monte Carlo
Dodge over heats
When you replaced the thermostat, did you bleed the air out of the coolant lines? When I replaced my thermostat on my old car forgot to bleed the lines out so it kept overheating until I did, then it worked fine. The air in the lines messes up the thermostat somehow and can cause it not to work like it should.
Oct 10, 2009 | 1997 Dodge Ram 1500 Club Cab
Overheating no heater
Sounds like a sticky thermostat. That would prevent coolant from circulating through the radiator and heater box. Your engine would overheat while the heater blows cold air.
Replace the thermostat and thermostat gasket; it's a cheap fix you can probably handle yourself.
Good luck !
Marco
Jun 17, 2009 | 2001 Nissan Sentra
Wiring of gas central heating
you have a link pin on 3-4 or 1-5 or seperate 2 pin connector,thats were the stat goes,any way round with wires
Mar 05, 2009 | Honeywell Programmable Thermostat Heater
All my radiators dont heat up
I must go to bed now but you may want to try going to http://en.allexperts.com/q/Heating-Air-Conditioning-696/2009/1/COLD-RADIATORS.htm
to see if this helps!
Hopefully someone else at FixYa will help you while I'm sleeping!
Good Luck!
0dc2daf.jpg jackiaria
Jan 31, 2009 | Combi Centre DX - Mango
Suzuki forenza thermostat 2004, 56000m
yas you can, drain the cooling system,disconnect the radiator hose at the thermostat housing cover , undo the two bolts and lift off the thermostat housing cover and gasket, withdraw the thermostat from housing, ri-fitting is the reverse sequence to removal , but use a new cover gasket and ensure that the thermostat is fitted with the jiggle pin uppermost . fill the cooling system .
Jan 19, 2009 | 2004 Suzuki Forenza
Heating & Cooling Logo
318 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
