Question about Jensen CD3610 CD Player
I need help! jensen 3610
I recently put a new engine in my car and now the radio doenst work.It worked great before,I check everyfuse,wiring.and it still wont turn on.all I get is the power light stays red and nothing happens..at all.and the instruction manual made itself scare. Thanks
  • 3 more comments
  • 2001honda Nov 16, 2007
    I have the same problem. the red power button lights up but nothing works!! its maddness! Ive checked all wires and fuses all the simple things and i cant seem to find the problem!
  • Grif2cool Jan 21, 2008
    I have the same problem and if I unplug the power cord from the back of the radio and plug it back in it works OK until I turn the car. I repair the 3610 with a 6112 and it works fine, So it's in the radio not the wiring.
  • Grif2cool Jan 24, 2008
    I had to revise my first post to many mistakes. I have the same problem and if I unplug the power cord from the back of the radio
    and plug it back in it works OK until I turn the car off.
    I replace the jensen 3610 with a jensen 6112 which uses the same power cord and it works fine, So it's in the radio not the wiring.
  • Anonymous May 12, 2008
    I dry fitted the Jensen CD3610 and no need of universal brackets. Then I bought the harnesses for the new toyota that I am installing this radio, wire for wire as instructed by the radio itself and the package of the harnesses I wired it, snapped in the harness from the car into the retro harness that I bought, I got power BUT NO sound. I flipped thru all the modes of the radio (bass, treble, fading, balance, volume, AUX, sound modes and even the MUTE button) all power works except we have no sound. I put back the old radio and it plays fine.
    I pulled out the fuse that is visible to see what would happen and still no sound.
    There’s 8 set of wires for the speakers, I would think that we could hear at least one speaker (even static or a crackling)
    Is there any other fuses? Is there a way you may know how to test the radio without taking my dash apart again? Please advice, Thanks, CHI_TOWN
  • Chi Town11 May 12, 2008
Well, I admit it was poorly phrased, BUT, the problem here is that the red ignition wire isn't receiving power, thus the radio partially functions, but isn't being told to turn on.
Posted on May 06, 2009
    Problem Solver:
  • 3 Answers
Don't take this the wrong way Jexx, But did you hook up the red ignition wire? Come on give us alittle credit please.
Posted on May 11, 2008
    Scholar:
  • 148 Answers
Hmm, did you hook up the red ignition wire?
Posted on Nov 05, 2006
Jensen RV cab radio does not have power in the key accessory mode.
Sounds like you need to land the Key On Power to a different point.
Sep 11, 2018 | Jensen Cars & Trucks
We have a Jensen XCD9622.The radio didn't work so we purchased a verified working one on ebay. We have power in the wiring harness but the radio will not turn on.We now have two that won't work.Ideas?
Most in car audio of the type needs at least two supplies and a ground.
It seems something is not quite right...
You need a wiring diagram of the radio requirements and then before connecting the radio test the vehicle wiring to ensure it meets all the requirements.
Jul 22, 2018 | Jensen Car Audio & Video
I purchased a used Jensen UV10 from a friend and installed it in a 97 eclipse spyder. I recently bought a 2003 chevy silverado 1500hd LX, and took out the aftermarket JVC cd player to install my Jensen....
Depending on the model, the Silverado may have an amplifier between the OEM radio and the speakers. If that is the case, you will have to remove it and wire directly to the speakers. Check the wiring schematics for the original truck radio option (one source is Alldatadiy.com).
Jul 16, 2017 | Cars & Trucks
I have a 01 Mercedes E320 and I put a jensen vm9213 in. It was working great until I had to change the battery. Now I'm not recieving power to my radio. Can you help?
1. Check the fuse at the radio and in the vehicles fuse box 2. Check the wiring of the radio to ensure nothing has come loose/disconnected 3. Remove the radio and test it on another power source to ensure it is working properly.
If it's not the fuse (Step 1) I recommend visiting a quality local Car Audio specialist and getting them to assist you.
Feb 06, 2011 | Car Audio & Video
Jensen cd player no longer working(self-installed)
First check the wiring to the radio. You may measure the power being ok but you also need to make sure the ground connection is ok. If this is all ok it may be that you have dry solder joints on wiring socket inside the radio or a blown track or protection diode.
Sep 17, 2009 | Car Audio & Video
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
Sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Nov 19, 2008 | Car Audio & Video
Jensen vm9410 wont power up
easiest thing first. check the fuse on the hot wire on the radio harness. next, check to ensure the hot wire is to battery power, and the acc (likely yellow or orange) is attached to a wire that turns on with the ignition. next, check to ensure good ground. all this should take less than 10 minutes.
Apr 06, 2008 | Jensen VM9410 Car DVD Player
I need toby past e brake
on your remote control press 1 2 3 4 and then press and hold the number five until the hidden menu appears
there is an option to by pass the brake
David
Dec 07, 2007 | Jensen VM9510 Car DVD Player
Power Button
yeah the samething happend to mine.i thought it was my cd,cuz every since i put a new cd in the cd3610 has been actin funny.but i think its just the jensen product
Aug 06, 2007 | Jensen CD3610 CD Player
Jensen CD3610 CD Player Logo
220 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
