Broken usb port, Acer desktop
The little black plastic parts inside my usb port have broken off. The computer is a dinosaur that I just use as a storage device and have my printer connected to. I don't want to spend a fortune fixing it and want to know if I can buy a new usb port and plug it in? I can easily remove it.
  • 1,901 Answers
May be hard to find.
If you have a spare PCI slot in your motherboard, I'd buy a cheap USB card and install it.
Here's some cheap ones online:
You may also be able to get one on eBay reasonable.
Posted on Nov 08, 2008
Can I use a regular desktop keyboard with USB plug into my older laptop Acer 5100? If so how does it work?
May need to download proper driver if Windows doesn't install them automatically. Power down plug in and restart.
Feb 20, 2017 | Acer Computers & Internet
Ports on acer travelmate 4200 not working?
sounds like you may have driver for usb ports missing. check in device manager and see. if so simply reinstall drivers
Aug 12, 2012 | Acer TravelMate 4200 Series Laptop Charger...
Well, one of my USB ports is broken. But, if one USB port is broken, the other one isn't working. What can I do to fix this problem? Is there a way that I can find the parts to fix this??? Also, it's...
Perhaps a couple of the contacts are shorted against one another. A Youtube search for disassembly of your laptop should show you how to disassemble it, but I suspect the USB ports are soldered to the motherboard.
If you can look at the broken port and cut out any loose, r shorted wire, you might get the other to work. You could also plug a self-powered USB hub into the other side, if it's working.. much cheaper than a new motherboard.
Jan 29, 2018 | Acer Aspire 5516-5063 Notebook
Broken black piece inside usb port
This is usually going to be a part replacement problem. the black piece is part of the connectors. and backs up or guides the connectors. you can go to your local computer parts store such as frys, or an electronics parts house. and buy the connectors unless it is one that is attached to the motherboard in the back of the computer. if this is the case and you do not have enough usb ports, then you have to get an external usb hub. usually a powered hub is best.
Nov 12, 2009 | Computers & Internet
USB port of a desktop computer is broken; I mean the plastic piece came off. Is it possible to change this port, say from parts from an old computer?
you might have to take your computer to a computer tech so he can probably replace/repair it... cause i don't believe you can do it because of how hard the alignment has to be...
Oct 01, 2009 | Televison & Video
Dell P1500 Laser Printer: USB Port is Broken--plastic center peg broken off
If you mean the centre pin from the plug has broken off in the socket then use a tooth pick, dab a tiny bit of cyanoacrylate, (super glue) on one tip and push against the broken pin keeping steady for at least 20 seconds. Now, gently pull the pin out.
If the socket is broken, new board or repair shop.
May 19, 2017 | Office Equipment & Supplies
USB port broken on old IBM Thinkpads
Thanks for providing the pictures. You don't know how much that kind of input helps!
In looking at the pictures you've sent, the only way to repair this is to replace the connector. It can be fixed, however you need to be aware that the cost to obtain a part as old as this plus the labor involved will probably be much more than the unit is worth.
One thing that you might want to try is to buy a USB hub and plug it into the working port. A USB hub is a kind of extention cord that will give you several USB ports.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Nov 20, 2007 | Computers & Internet
Broken Prong inside connector for mouse
If the ps2 port on the main board is broken you will need to replace the board. If this is the case and your computer has usb ports on it just go out and buy a usb mouse.
If the part that is broken is from the mouse by using tweezers try to gently remove the broken part from the board. if unsuccessful use the usb port with a usb mouse.
Oct 21, 2007 | Computers & Internet
Computers & Internet Logo
401 people viewed this question
David Payne
David Payne
