Question about EliteGroup P4M800-M7 Motherboard
P4m800-m7 Rev:3.1 RAM PROBLEM!
Hi i have a p4m800-m7 Rev:3.1 motherboard with 256mb 266mhz ram and i removed it to install 1Gb 400mhz ram.. the pc boots and recognize the ram.. then trying to install a fresh copy of windows xp and it says "Error code 7" i removed the new memory and installed the old memory... Then trying to install windows and it worked... then i removed the old memory and installed the new memory and the windows wont boot! i changed then the ram to 266mhz 1Gb and the computer wont boot at all!! i updated the bios and nothing happened! any suggestions to upgrade the memory?
  • Insanity87 Nov 10, 2008
    dear suisboy i changed 5 ram on both slots! 1GB 400mhz and 1GB 266mhz! with the1GB 400mhz the computer opens but the HD wont boot! With the 1GB 266mhz the computer wont start!! BUT with the 256mb 266mhz the computer starts normaly and boot normaly in the windows!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
The problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Posted on Nov 08, 2008
Does ''FOXCONN 8657MF-series'' supports 400mhz fsb of RAM
Yes, you can add it. The faster 1 GB will be downclocked to the speed of the slower 256MB.
 But it would be better for performance to remove the 256 MB one completely.
May 05, 2010 | Foxconn Computers & Internet
About my ram of p4m800-m7 rev 3.1 i have a 512mb ram already installed and i buy a new ram with a 1gb size and i would like to install it but my question is is it okay to put them together? my 512mb ram is...
The black rectangular chips on the side, or sides, of the ram module are DRAM chips. Dynamic Random Access Memory.
('Chip' is slang term to denote IC, or Integrated Circuit)
Each Dram chip is of a specific size, (or can be said as Amount)
There are manufacturers who make the Dram chips, and then the chips are used by the ram memory manufacturer.
Doesn't matter how the Dram chips are arranged. The ram memory manufacturer could put them all of one side, if they designed it that way.
1.Your motherboard will support, (Use), DDR at 333Mhz, or DDR at 400MegaHertz.
(PC2700 and PC3200, respectively)
2.The ram memory module must use 2.5 Volts.
(JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts, so no worries here. Only time to check this, is if you have some High performance ram, that may be set to use a higher voltage)
3.It must be Non-ECC ram, and Unbuffered.
4.Cas Latency should be 2.5 to 3.0 (Ram Timings)
Short solution?
Computer off, and unplugged from power. TOUCH the metal frame of the computer case to relieve your body of Static.
Handle the ram 'sticks' by the body of the stick, and refrain from touching the gold plated contact pins, on the bottom.
If the 512MB stick is in SLOT 1, remove it. Install the 1GB stick in Slot 1. Make SURE it is seated!
(Slot 1, is the ram memory slot that is closest to the Processor. It is the first ram memory slot that the Processor reads)
Leave the computer case open. (Refrain from putting your hands in while the computer is plugged into power)
Plug the computer into power. Wait 30 seconds. Turn the computer on.
Computer boots up? (Starts)
Okay.
Unplug from power. Install the 512MB stick in Slot 2.
Plug into power, wait 30 seconds. Turn the computer on.
Computer boots up?
You're good to go.
1GB ram memory stick is in Slot 1, and the computer does not boot up?
Incompatible ram memory. Remove it. Reinstall the original 512MB stick in Slot 1.
Nov 26, 2009 | EliteGroup P4M800-M7 Motherboard
Hi I also have a P4m800-M7 rev 3.1 motherboard and a 512mb of ram.. my question is, is it okay to put another ram but in 1gb size its pc3200, will it work? thanks!!
The motherboard supports 2GB maximum memory. 1x1GB in each slot.
Maximum clock speed is 400MHz (PC3200), so the memory module you have should work fine.
Please remember to remove the power cord before installing the new ram.
Regards.
Nov 25, 2009 | EliteGroup P4M800-M7 Motherboard
Hi..i have a P4m800-M7 rev 3.1 motherboard which recently had only 1 512MB DDR 400mhz RAM.. itried to install an additional 256MB DDR 400mzh ram but the system recognizes only the 512MB RAM. I've tried...
Check that your memory is supported, according to Biostar documentation for your motherboard:
Single Channel Mode DDR2 Memory
Registered DIMM and ECC DIMM is not supported
Re-check the memory module's specifications.
Nov 03, 2009 | EliteGroup P4M800-M7 Motherboard
RAM Help!
Hi there.
Yes it is related to PC2 and it runs at 800Mhz, this why your system is seeing only half the speed, your system does however support a module running at 333 module and a 400 module, this is the base limit that the memory runs at.
If the memory was 533 then the computer would not start up because the bios wouldn't recognize it.
Thanks for using FixYa!!
Apr 22, 2009 | EliteGroup P4M800-M7 Motherboard
Ram upgradation for 845glad mother board
Hi! If you have orignal Intel D845 then you need ram less than 333 Mhz (Around 266mhz or so) and do remember to check that it is advisable not to use RAM of more than 1GB as you won't be able to find a 1GB RAM(DDR1) with 266 Mhz or less.
May 16, 2008 | Intel Motherboard
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Can i use DDR2 RAM in intel 865GBF motherboard?
NO ! you can only use DDR 1 ram (266Mhz,333Mhz,400Mhz) speeds only
Mar 30, 2008 | Intel D865GBF Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
651 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
