Question about Toshiba 28N33 28" TV
TOSHIBA Model: TV28C30 - No Vertical. Just flat horizontal line.
A couple of days ago I turned my set on and got no picture. Instead, just a flat horizontal line centered in middle of picture tube. No problem with sound. I have no service manual for this TV. So, I am hoping someone will direct me as to which component burned out? Thank you. GerryW
  • 1 more comment
  • siggy60 Feb 14, 2008
    turned on this am nothing but line across middle of tv sound is fine
  • Anonymous Feb 18, 2008
    Same problem turned on TV flat red horizonal line across the middle. Sound is fine.
  • Anonymous Mar 22, 2014
    Sound is good, and if you bump the outside housing of the television sometimes the picture will come back for a little while.
    President:
  • 3,130 Answers
The vertical output IC is most likly bad or has a bad connection on it. Its a stand up IC witha metal heat sink and should start with an LA number. There ciould also be a problem with the B+ feed if you replace the IC and still get no vertical deflection. The parts would be in the sweep power supply and would start with the same first number thats printed on the printed circuit board, that is printed by the vertal sweep IC, meaning if the IC number on the board was IC412, then the B+ supply parts would start with 4 also ie r456, d456,c435 ect ect. The numbers I used are not the actuall numbers just used for referance. If you need a schematic one is available at http://www.servicemanuals.net for a download price of about 24 bucks. Remember though to always be safe and if you have no solid state repair experience, please consult a pro to assist you with this repair. Good Luck Please dont forget to rate this thread.
Posted on Oct 20, 2006
    Scholar:
  • 68 Answers
Gerry, A vetical timebase failure like this is not bad and should not take a Serviceman long to fix if he has the all important service sheet, or circuit diagram and an oscilloscope. It is worth looking in the back, if you can obtain some layout details, and with it switched on, use a long dowel rod to prod the part of the circuit, as it may just be a dry joint, or burnt resistor.
Posted on Oct 22, 2006
This is a very common problem with Toshiba CRT TV's. There are a couple of electroytic capacitors near the vertical deflection amplifier (VDA) which become leaky, then the VDA blows out. Replace the VDA and the electrolytic capacitors near it (sorry, don't have a schematic to tell you exactly which two); if you just replace the VDA without replacing the caps, the new VDA will justblow up in a matter of seconds-minutes.
Posted on Aug 12, 2008
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Horizontal line going through the screen of my tv
    the vertical IC of your tv might cause the problem you need to replace that..replace also the capacitors near the ic...resolder the high voltage section and the vertical section..tnx and good luck!
    Jun 14, 2010 | Televison & Video
    Horizontal line in toshiba TVs
    its the horizontal output IC
    Feb 14, 2010 | Toshiba 28N33 28" TV
    Toshiba rear projection TV 43VH9UA
    have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
    May 12, 2009 | Toshiba 43H72 43" Rear Projection...
    Toshiba 32A40 32" TV Problem
    does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
    I only see a horizontal line on my Tv.
    thanks.
    teranco@hotmail.com
    Jul 13, 2008 | Toshiba 32A40 32" TV
    Lines on tv
    Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
    I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
    White horizontal line (no vertical deflection)
    Check / replace R548, R549
    Sound but no picture except for a couple of horizontal colour lines
    Replaced the frame chip TDA8356, set now ok
    Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
    No picture, only sound
    The set has a shorted vertical output IC, probably a TA8427k. The capacitors around the heat sink of this IC dry out and cause the IC to run hot. The correct repair is to replace the vertical output and the electrolytic capacitors near it. Also use 105 centig instead of the original 85 centigrade. The is some time a pico fuse or current limittng resistor which must also be replaced. This a common problem with Toshiba and is not a bad picture tube. The usual cost of this repair is around $120-150 depending on the integrity of the technician. Scrivitron
    Jun 18, 2007 | Toshiba 27DF46 27" TV
    Toshiba 36A40 36" TV / Chassis No: TAC 0011
    Bad capacitor in vertical circuit + possible vertical output IC
    damage.If you can identify part locations and solder.....?
    May 24, 2007 | Toshiba 36A40 36" TV
    Toshiba 28N33 28" TV Logo
    1,969 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
