Question about Sharp AR-407 Copier
Developer installation code
Dear friend
i have problem with sharp 407
i need service code
  • pion46 May 11, 2010
    Code for developer replacement? That would be 25 - 2
  • Sharp Expert
  • 257 Answers
Press P, Interrupt, C, Interrupt keys.
Enter 25 press Start enter 2 press Start then press Execute.
After it stops press CA key or OFF then ON.
Posted on Oct 27, 2009
    Problem Solver:
  • 6 Answers
Press
program - interrupt- c- interrupt
Enter the code that you want press then press start.
Posted on Sep 22, 2009
Service code for H3-00
fuser section has overheated. clear>pause>0>pause>14>1>start button to clear it.
Apr 27, 2015 | Sharp AR-286/337/407 Developer Black...
My copier needs developer. i would like to know how to install developer and the code to calibrate the developer
On the AR-407:
To remove the developer/toner cartridge, there is a green lever inside the front door/cover. Pull it down like you are going to refill the toner, pull it out, and there is a release lever on the right side bottom, between the cartridge and the copier. This will release the cartridge and allow you to slide the whole mechanism out.
There are 4 screws that hold the toner box onto the developer. (NOT THE TOP MOST COVER SCREWS) 2 on the left side (with the toner hopper on your right), and 1 screw on the right top, and 1 screw on the right side by the handle you use to pull the cartridge out of the machine. Make sure you also disconnect the electrical connector that attaches to the hopper motor.
Be careful not to spill the toner or developer as you are seperating the two.
The developer unit is the bottom unit.
Dump out old developer (make sure you get all of it by turning the gear on the back side). If you don't have a toner/developer vacuum, then just get as much out as you can. A normal vacuum motor will eat itself in a very short time trying to vacuum up toner or developer, because the particles are too small for a regular filter.
When you get all the developer out, then carefully open the new developer packet, and evenly pour it in. Put it back together the same way you took it apart.
Reset Developer counter : Simulation 24-5
Hope this helps!!
Ryan K
Nov 02, 2010 | Sharp AR-407 Copier
Needs maintenance
Maintenance doesn't necessarily mean developer replacement, if its working well, ignore developer and continue if it requires, pullout the developer unit and remove the toner hopper. Then empty the used developer and put new one. To empty, turn the dev unit upside down while rotating the magnet roller clockwise the return it in normal position and pour the new developer while turning the magnet roller clockwise until evenly distributed. Put back the toner hopper and screw back and install inside the copier then set it with 'P, Interrupt, C, Interrupt keys enter 25 press Start 2 then Execute key and allow to run till it stops then press Interrupt twice and Press 24 Start 3 Execute . Finally Switch OFF and ON.
May 07, 2009 | Sharp AR-407 Copier
Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Apr 11, 2009 | Sharp AR-407 Copier
Sharp AR 407
Hi friend,
Thanks for your assistants
there was a problem in developer unit pin(PJ Jack)
i found and solve the problem
once again i thank to u my friend
Nov 12, 2008 | Office Equipment & Supplies
Sharp AR 407
Try this procedure:
http://olsonbros.com/sharp/support/ar16x_devinstall.html
Nov 11, 2008 | Office Equipment & Supplies
Sharp AR 407
You will need to get some developer.  Usually you can get it from who you get your toner from.
Remover all developer out of the cartridge using a vacuum.  Carefully remove all developer off of the mag roller as well.
Install developer evenly into the cartridge.
You will need to run a service code to initialize the developer and reset the counter.  If this isn't done properly, the developer will get contaminated and have to be removed again.
You should obtain a service manual for step by step instructions on how to replace the developer for your particular copier.
SERVICE MANUAL
you may want to call a local dealer..
Nov 08, 2008 | Office Equipment & Supplies
Sharp AR-407 Copier Logo
179 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
