Question about HP LaserJet 4250n Printer
50.4 Fuser err
When swithed on the printer after all intial checked its show "ready" mode when i am start to print shows " 50.4 Fuser err" .
Would you please help me in this regard.
nehikons@yahoo.com
  • 100 Answers
If that does not work replace the fuser unit. Usually that is the cause
Posted on Jan 06, 2009
  • 57 Answers
Hi nehu1,
your problem exist with your line voltage:
1\ disconnect printer from any UPS , stablizer, additional power supply or power strips .
2\ plug the printer into a wall outlet and see if this resolve the problem.
3\ If the printer is already plugged into a wall outlet, try another power soource in the building that is independent of the one currently being uesed.
4\ The line voltage and current source at the printer location might need to be inspected to ensure that it meets printer's specification
hope this helpfull;
thanks,
Hamedo
Posted on Nov 08, 2008
Why is my HP 100 color MFP showing cool down mode
Cool down mode is a function that prevents damage to the fuser due to overheating. It prevents flat spots on the fuser. You should not turn off the printer when it is in cool down mode. Wait for it to return to ready. If it occurs in the middle of a print job, just wait for the job to continue after the fuser temperature has stabilized.
Dec 10, 2014 | HP Office Equipment & Supplies
Canon ir3570 show error 00024
check for paper jammed in fuser assy, u need to reset error code by pressing smarthead then 2and 8 SAME TIME then smarthead should go into service mode press copier then function then err ok then off on
Feb 19, 2013 | Canon ImageRUNNER 3570 Copier/Printer
KEOCERA MITA photocopier KM4035 have problem. My Machine is showing error code C6000. How to tackle this proble. Please help me as soon as possible.
KM/CS 2530, 3530, 4030, 3035, 4035, 5035
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Press EXCUTE on the touch panel. It is displayed in reverse.
Press "Start / Print key.
The machine will turn off and then back on then come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Feb 02, 2011 | Kyocera Mita KM-4035 Printer
Ir6000 error code e246-0002
fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
Shows 50 service in printer window
ok its either going to be your psu unit or your fuser.... if its showing the 50 service and doesn't print anything I would definitely replace the fuser... here is a link with some more information on the matter... http://www.fixyourownprinter.com/kits/hp/K05
Jan 06, 2010 | HP LaserJet 4 plus Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
Fuser jam.code E00070000
You have to change the fixing film or the fuser unit which ever is the cheapest but before you do check the counters to see the the fuser has done its copy life.
When you do change the fuser dont forget to reset the error code in service mode of else the code will appear even when you replaced the unit.
You do this by entering in service mode and select
Press the key face key, ‘2’ and ‘8’ at the
same time, and the face key once again. then
COPIER>FUNCTION>CLEAR>ERR.
Oct 06, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
How do I fix this?
please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service morefunction/clear/error/ok/ exit service mode and cycle power.
fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
Fuser error codes cannot be reset by power cycling the machine eventhough that is what the display tells you to do. In order to reset thefuser error code you must enter the service mode & reset the code.To enter the service mode:
press the #2 and #8 at the same time (simultaneousley)
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Afterclearing error stay at the machine to see if it comes to ready. Thefuser assy can reach 139 degrees C.(Water boils @ 100C) The error canonly be cleared through the service mode because a technician shouldinspect the fuser to verify there is nothing faulty that could possiblystart a fire. If you enter the service mode & clear the error,power cycle the machine & during warm up the machine throws a codeagain- turn it off, unplug it & call a tech for fuser repair.
Good Luck!!
Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
Canon printer IR2016J show error code E007. Please advised me on how to resolve it or rese it. Thanks
i have a canon copier IR2016J shows me error code E007 please advise me on how to resolve it or rese it. thanks
Jul 01, 2008 | Office Equipment & Supplies
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
HP LaserJet 4250n Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
