SERVICE MANUAL HI FRIEND, IM PRABU.. I NEED SERVICE MANULA FOR SHARP AR 407 I HAVE TROUBLE IN THIS SHARP MC PLS
  • 145 Answers
You may want to call a local dealer..
Posted on Nov 09, 2008
Hello, how do i replace the developer in my sharp ar407 copier? please help me!
http://www.eserviceinfo.com/download.php?fileid=41998
Hi ,i uploaded the service manual at the above link in 3 sections.Download all 3 sections before unzipping it and it comes in pdf format.The dev section is on page 4-6 if i am right.good luck and let me know.
Jun 23, 2009 | Sharp AR-407 Copier
Sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Apr 28, 2009 | Sharp AR-407 Copier
Sharp ar-m162
E1 00 Content IMC PWB communication trouble.
Detail An abnormality occurs in communication between the MCU PWB and the I
MC PWB.
Cause IMC PWB-MCU PWB harness abnormality.
MCU PWB connector disconnection.
IMC PWB ROM defect/data abnormality.
Check and remedy
1. Check connection of the connector and the harness between the IMC PWB and
the MCU PWB.
2. Check the ROM of the IMC PWB.
Feb 12, 2009 | Sharp AR-M162 All-In-One Laser Printer
Sharp AR 407
Hi friend,
Thanks for your assistants
there was a problem in developer unit pin(PJ Jack)
i found and solve the problem
once again i thank to u my friend
Nov 12, 2008 | Office Equipment & Supplies
Sharp AR 407
Try this procedure:
http://olsonbros.com/sharp/support/ar16x_devinstall.html
Nov 11, 2008 | Office Equipment & Supplies
Sharp AR 407
You will need to get some developer.  Usually you can get it from who you get your toner from.
Remover all developer out of the cartridge using a vacuum.  Carefully remove all developer off of the mag roller as well.
Install developer evenly into the cartridge.
You will need to run a service code to initialize the developer and reset the counter.  If this isn't done properly, the developer will get contaminated and have to be removed again.
You should obtain a service manual for step by step instructions on how to replace the developer for your particular copier.
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
165 people viewed this question
jasbo
jasbo
