Question about EliteGroup P4M800-M7 Motherboard
Mikeduque22 the motherboard only supports 333mhz and 400mhz of ram! if u put a 266mhz the computer wont start! if u put 533mhz the computer will read only the half memory!
  • Insanity87 Nov 08, 2008
    thats a wrong post sorry... check my other problem on the unsolved list pls
Have try changing the setting on the bios.
Posted on Nov 08, 2008
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Computers & Internet
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Which type of ram does support this board
Hi, this board supports the following.
DDR SDRAM
400MHz or 333MHz or 266MHz, the 400 is the fatest and the maximum amount of memory is 4GB
Oct 05, 2010 | Gigabyte GA-8IG1000MK Motherboard
How do i change the memory bus speed on my dell optiplex 170l? The CPU is an Intel Celeron 2.4GHz. The mother board processor speed is 400MHz and the Bios indicates a memory bus speed of 266MHz and does...
You checked in the right place as far as looking in the BIOS, however, memory and CPU sockets do not necessarily have the same buss speed. My FSB runs at 1066Mhz and my RAM at 800Mhz, it all depends on what type of RAM you buy as to the bus speed. You can up the bus speed on your RAM if you wish to reduce bottle-necking, but I've only done that a few times. In order to adjust anything, you must set the settings to manual. Be careful when you change this stuff around though, voltages must also be adjusted accordingly.
Feb 28, 2010 | Dell OptiPlex 170L PC Desktop
Emachine 4250 wont boot gives 3 beeps
beeps indicate a hardware fault, go to the manufactures sight to determine the nature of the fault
Jan 25, 2010 | Computers & Internet
RAM running slowly
hi there
this is very interting you are asking for fsb to adjest at 333mhz.
for this first you have to look your prosser fsb , *********** board fsb and your ram fsb.
fsb is a front side bus on which data ia is running at speed but for high speed you have to increase your fsb you are askin (ie:333mhz). itell you how?
example : your prosser fsb is 266mhz
your ram fsb is 400mhz as you told
*********** board fsb is 333mhz
now you system fsb is constant on 266 mhz because system on that fsb witch supporting by ram prosser and mobo( motherboard).
if you want to increase the fsb you have to buy mobo, ram,and prosser at same fsb.
Aug 15, 2009 | Dell Dimension 2400 PC Desktop
RAM Help!
Hi there.
Yes it is related to PC2 and it runs at 800Mhz, this why your system is seeing only half the speed, your system does however support a module running at 333 module and a 400 module, this is the base limit that the memory runs at.
If the memory was 533 then the computer would not start up because the bios wouldn't recognize it.
Thanks for using FixYa!!
Apr 22, 2009 | EliteGroup P4M800-M7 Motherboard
Upgrade Ram
No it wont take 800MHz RAM...
Using the DDR2 slots u can have 400MHz sticks (rare stuff), or 533MHz sticks
Using the DDR1 slots u can have 333MHz or 400MHz
Let me know...
Matt
Jan 20, 2009 | EliteGroup 945GZT-M (V1.0) Motherboard
I have a GA8ST800 board and I have have been running 256MB ram at 266MHz. I fitted a 512MB ram at 400 MHz. The two together would work fine, even though they were running at 266MHz. I bought two 512MB...
The RAM speed of the new chips is too fast. You need the slower either 266mhz or 333mhz RAM speed to make your system stable again. Hope this helps.
Dec 27, 2008 | Gigabyte GA-8ST800 Motherboard
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
41 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
