Question about Insignia Digital-to-Analog Converter for Analog TVs
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Interesting question here.
Elderly relatives of mine moved to a house where the Cable was never turned off from the previous homeowner.
They cannot get TV Guide Channel now for example though, as it apparently went digital.
  1. Would hooking Cable up to an Insignia Converter box work at all?
    Also, I’ve read that "digital" processes allows Cable Companies to have two-way data transfer now, allowing customer info to come back via their Cable box connection.
  2. Would hooking up an Insignia Converter box to a live Cable connection make it visible to the Cable Company? Or would this two-way data transfer be limited to only the Cable Companies own converter box setup?
Thanks,
Tom
  • Tomitsme Nov 09, 2008
    https://www.fixya.com/secure/users/maser...">masers1004,
    Thank you for your response.
    This Cable has been left on for 6 years now. It was just recently that a few channels have gone off.
    I would be tempted to try hooking the Insignia unit up to the Cable line for my relatives just to see, but then again I wouldn't want to risk having their connection now becoming "visible" to the Cable Company via the added digital means.
    That's the only thing that prevents me from attempting that for them. I wish I knew the answer to that.
    Thanks,
    Tom
  • Tomitsme Nov 10, 2008
    Master,
    Thank you so much.
    I mistakenly gave you the wrong rating, sorry.
    It should have been "FixedIt".
    This was an odd question I proffered to start with I'm sure, but that is where these forums come in handy.
    Again thanks!
    Tom
  • 34 Answers
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
Posted on Nov 08, 2008
  • Brandon M. Nov 09, 2008
    That converter box want work with cable tv service. The cable signal coming in is down converter at the cable office to analog. Also if you hook up that box there isn't anyway the cable company would know because the cable service is only a one way communication signal. The only way they can see what is going on at a home is if they have one of their cable boxes in the home with the appropriate software. Also to get digital cable channels through coax you have to have a hd tv with a qam tuner built into the tv which is common on the new hd tv's in which converter boxes don't have that ability.
How do you hook up cable box using coaxial in hdmi out
If your cable box has an HDMI OUT connector you simply connect the HDMI cable to the TV and the coaxial cable from the cable company to the coaxial input on the cable box. Then select the HDMI input on the TV that matches the number of the HDMI input port you chose on the back of the TV.
Mar 03, 2016 | Insignia NS-LCD32 LCD TV
How do I connect a cable plug to my Insignia monitor without a cable box? I checked 32 in but I think mine is 19/20 in. Thanks
The port should be labeled as RF In or Antenna/Cable In, screw the coaxial connection onto that and then run a channel scan from inside the TV menu.
Jun 12, 2011 | Insignia IS-LCDTV32 32 in. Television
My Insignia Converter boxes - 7-19-09
Switch to a powered DTV antenna.
Your analog antenna may be too far out of range to effectively pick up signal.
Thanks for using FixYa!!
Jul 19, 2009 | Insignia Digital-to-Analog Converter for...
Casio EV 550 B portable TV 3" screen many of "us" with portables are wanting a "FiX" instead of landFILLing our sets when the switchover comes apon us. Is there a DTV FiX? costs? Are there portable DTV's?...
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that connects to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Jan 26, 2009 | Casio TV-980 2.3 in. Handheld Television
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Lost the Welcome/Installation Menu
http://www.ezdigitaltv.com/support-files/ns_dxa1_manual.pdf
All you have to do is use the auto tuning function. Your remote control has a menu button, you can get to the feature via the on-screen menu.
If you press the menu button while the box is on and you see no menu, change your television's input to match what the box's output is.
Nov 23, 2008 | Insignia Digital-to-Analog Converter for...
Are there converters 4 hand held casio 880B
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
A few other tips:
Nov 11, 2008 | Casio TV-980 2.3 in. Handheld Television
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Hand held casio tv vs digital signal
A few other tips:
Apr 29, 2008 | Televison & Video
Using vcd/dvd combo with digital converter box
"Sounds" correct to me.  Are you going by the instructions that came with the converter box?  And, "ANT In" to the box from your antenna?
Apr 04, 2008 | Samsung DVD-V8600 DVD Player/VCR
Insignia Digital-to-Analog Converter for Analog TVs Logo
226 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
