Question about HP Officejet 5610 All-In-One InkJet Printer
HP L7680 Printer Head Problem
How do you clean the printhead of the HP L7680? How do you determine when it is necessary to replace the printer head. I am having a printing problem with it showing streaks and missing portions of the characters when printing. I have taken the printhead out and applied a wet lint free wipe across the print head surface. The yellow ink tends to flow better than the black. I place it in the printer and it prints correctly a few times and then reverts back to streaking. I tried using the printhead cleaning routine but it doesn't do any good. What are your suggestions. I have only around 3500 pages printed on this machine.
    Novelist:
  • 183 Answers
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
If reprinting did not help, try increasing the print quality mode.
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only)
If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Step four: Clean the printheads
If the print quality is still bad, clean the printheads.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Step five: Align the printheads
If the print quality is still bad, align the printheads.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed
If the print quality is still bad, calibrate the linefeed:
Open the printer Toolbox and select the Printer Services tab.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads
If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
Press the Setup button.
Press 1 and * simultaneously.
Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
If the Black block has lines – replace the KY printhead.
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
If the Red block has lines – replace the KY printhead.
If the Green block has lines – replace the KY printhead.
Posted on Nov 10, 2008
How do I clean the print head on an HP Officejet Pro L7680 All-in-one?
I am assuming that you have installed the HP Solution Center software onto your PC. If not go online to hp.com, do a search for it, download and install it.
1. Open HP Solution Center
2. Click on Printer Toolbox
3. Click on Services (top)
4. Click on Clean the Printheads
Jul 07, 2014 | HP Officejet Pro L7680 All-In-One Printer
I am getting message "the
More black/yellow print head failure we observed in this series, no remidy for this issue replace the print head..
Sep 23, 2011 | HP Officejet Pro L7680 All-In-One Printer
How do I remove old printheads
Hi the below website explains how to fix print head errors and how to remove/replace the print heads in HP Officejet Pro L7680 All-In-One Printer
http://tinyurl.com/raj12345
Best Of Luck.......
Dec 09, 2010 | HP Officejet Pro L7680 All-In-One Printer
Can I clean the C9381A Printhead instead of buying a new one?
HP Printer using disposible head with a working system using thermal. So, you can not expect the cartridge / head of HP can be used for long periods of time. Indeed so, the head is designed with a design to be used in a limited time. If that happens heads clogged, remove the head, put on paper towels moistened with a head cleaner. Wait a few moments, just tune in and check the nozzle.
Sep 29, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP7680 Blk/Yellow printer head problem
Try unpluging the printer for about fifteen minutes or so.
Dec 12, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 won't print black, cartridge is new, says it is full, Self diagnostic page says printhead is good
Try printing a Diagnostic page or clean cartridge. Looks like the printheads might be clogged due to low usage or general wear and tear, they may not be working as desired.
Oct 26, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officejet pro l7680 all in one
Most likely the print head has failed and the black is not printing which is causing the printer to have issues. Talk to HP as I guess printheads have warranty or simply change the yellow/black printhead. Or if all of these fail give the machine to HP to get you a new one as this is not right. I hope this helps.
Nov 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 Print Head Problem
Sometimes the circuit strip that sits at the back of the printhead carriage is the problem due to moisture, ink soiling, etc...
To clean these you need some cotton buds (like you use to clean your ears) and gently clean the area at the back of the printhead carriage (where the printheads slot into).
This removes any ink, or moisture that could be causing a short circuit or similar.
Nov 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
1,630 people viewed this question
Ben Johnson
