Question about Sanyo DS13204 TV
Water in tv
Hi, My son has just squirted water into the tv! Into the red/yellow/white connectors at the front to be precise. And the problem I now have is that the tv is constantly changing the channel - would anyone have any ideas how to fix this - easily? is it just a case of letting it dry out? Thanks
  • Anonymous May 02, 2008
    i cleaned my tv now my volume wont work
    Sergeant:
  • 337 Answers
The push button assambly is wet too,I dont know how much water he put in there.If you are familiar with tv service remove the back cover and slide the chassis back so you can clean the buttons,this needs to be done before corrosion sets in,once it sets in it will give you other symptoms and all the buttons will have to be replaced,if you are not too familiar with tv service be safe and seek the help of a servicer.Good luck
Posted on Oct 20, 2006
  • Omar Urrutia
    Omar Urrutia Oct 20, 2006
    Your rating resonse is also important.
    Scholar:
  • 68 Answers
You may have fixed it by now, taking jomaru's advice, i'me afraid I have got a bit behind fixing things at home. If you get water in a television it will conduct as it is usually slightly acidic. Anything other than tap water or purer will require a service engineer to look at it, as it will cause problems if it goes on any contacts. The changing channels; may be the water is causing conduction between soldered joints on the circuit boards. If this is on the 30 volt tuner voltage output it will easily change the voltage randomly and give different channels. Just wait for it to dry out. If as on older sets there is a variable resistor, or potentiometer which has got wet this is more serious, and may need gentle heat from a hairdryer.
Posted on Oct 22, 2006
4 Suggested Answers
  • 298 Answers
SOURCE: magnavox hd2504
try turning the dvd player on,and
inserting a dvd,and then switching
to video the tv has to have a silgnal
when you switch to video the dvd
players splash screen should come
up,and then it will load the dvd
Posted on Nov 22, 2007
AUTOSOUNDINS
  • 232 Answers
SOURCE: changing from video 1 to tv channels...
IF THE TV DOESN'T HAVE A BUTTON U NEED THE REMOTE, U MAY GET AWAY WITH A UNIVERSAL BUT ONLY IFNITS THE SAME BRAND MAKER OTHERWISE U MAY HAVE GET THE REMOTE IF POSSIBLE OR USE A VCR AS THE NEW TURNER FOR THE TV, WHICH U CAN USE THE VIDEO OUTOUT TO INPUT THE SIGNAL INTO THE TV
Posted on Aug 11, 2008
maatmartin7
  • 1255 Answers
SOURCE: My sons may have squirted water into my dad's (old
Personally when I do encounter a TV with known water damage [set was plugged in of course] I will regretfully deny repair. It will be next to impossible to fully recover a repair. This is my very honest opinion!
Posted on Mar 30, 2010
Don't know radio connector color code
This should help.
1987-88 Plymouth Voyager Stereo Wiring
Constant 12V+
Red
Switched 12V+
Red/White
Ground
Ground/Back Strap
Illumination
n/a
Dimmer
Orange/White
Antenna Trigger
Yellow
Antenna
Right Front
Front Speakers
5 1/4" Dash
Left Front (+)
Green
Left Front (-)
Green/Yellow
Right Front (+)
Purple
Right Front (-)
Purple/Yellow
Rear Speakers
6" x 9" Tail Gate
Left Rear (+)
Brown
Left Rear (-)
Brown/Yellow
Right Rear (+)
Blue/Red
Right Rear (-)
Blue/White
Sep 20, 2011 | 1987 Plymouth Voyager
Hi, I'm having a bit of trouble setting up our hard drive and playstation 3 up to the plasma as the cords are yellow, red and white but on the back of the plasma they have red white red blue and green and...
The red whit and yellow connectors are for the Component connectors, your cable is for Composite connection - incompatible one to each other.
Your tv also has that yellow red and white connectors somewhere on it - probably on the side. Plug the cable there and respect the color coding or it will not work.
Sep 26, 2010 | Televison & Video
I have a Dell 5.1 surround system that I bought for my computer. It has three cables, yellow, black, green, that connect to make it a single jack for the computer. I would like to hook up this system to...
well you can connect white and red to green connector(Front Speakers) the yellow connector is subwoofer speaker and the Black connector is for Rear Speakers) is not connected. The Tv dont have any Surrond decoder so to have full surrond needs surrond decoder
Jan 08, 2010 | Audio Players & Recorders
I am trying to play back video from Sony Handycam on tv, the sound is perfect but i have no picture, im sure it must be something simple. i have handycam a/v out attached to the yellow red and white...
    First remember that the "Yellow" is for video signals the Red and White are for audio.
    first connect the camera leads directly to the TV. First yellow connector of camera attach with the "Video in" of Tv and same as Red and White of camera as Audio IN of Tv. And you will both get sound and audio.
     Now same as connect the camera connectors Yellow in Video In of the DVD and Red & White For Audio In in the DVD, Now a new lead connect to DVD out Video "yellow pin" to the TV Video IN ans same as Red & Whit in TV IN. By this procedure you will get the Video and Audio from your camera.
     Hope this will help you.
     Thanks.
Dec 01, 2009 | Sony Handycam DCR-TRV245 Digital-8 Digital...
Orion tv without input/output plugs
from the looks of the picture you have one audio video input port on the front of the tv. The connectors are yellow and red or yellow and white. Yellow is video and red or white are audio. Find those same connectors on the back or your dvd player, hook it up to the tv and there you go. You'll have to go to game mode or input 2 on the tv to see the dvd player.
Jul 01, 2009 | Orion1934 19" TV
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
Connection cord problem from VR375 to TV set?
Page 18 of the user manual for your device shows that there are normal video (yellow) and audio (red/white) connectors underneath the A/V out column of connectors - Since your son's TV does not have an HDMI cable (all you would need if that were the case) make sure you connect the A/V out column to the RCA type inputs of your son's TV.
The manual can be found here:
http://downloadcenter.samsung.com/content/UM/200802/20080229102004125_01613A-01-VR375-XAA-ENG-BM-0228.pdf
Dec 31, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Black and White Only
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
Jan 30, 2008 | Microsoft Xbox Console
Sanyo DS13204 TV Logo
227 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
