TV Capacitor Replacement
I have a Sony TRINITRON KV-27HSR10 TV set which works but the picture flickers pretty badly during power up. It's been checked before by an electrician and he said a capacitor must be replaced. Specifically, a 10uF 250V electrolytic capacitor.
I have a soldering iron and want to replace it on my own. I don't remember which capacitor it was on board, but I'm guessing the capacitor should be leaking or bulging.
I wanted to know which capacitors will I need to discharge in order to safely work on the board? And will I need to discharge the TV tube?
  • 556 Answers
SOURCE: Sony Trinitron KV-1670 TV
please visit www.serviceinfo.com after site is open go to search and give model no Sony Trinitron KV-1670 TV. you will get the map. good luck
Posted on Sep 22, 2007
  • 556 Answers
go to web site www.serviceinfo.com it is available you will have to download.
Posted on Sep 29, 2007
SOURCE: Circuit board diagram for Sony TV Model no. KV-T25SZ8 Serial no.1015982
no power standby & no sound
Posted on Feb 18, 2008
  • 4234 Answers
SOURCE: Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
Posted on May 19, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
SONY KV-32xbr50 intermittent
The fault is with some loose contacts. Check and rectify this. There is no more components to replace. Look for any loose solder terminals. That is all. But it will be a difficult task to reach to the exact point of fault.
Oct 01, 2012 | Sony KV-32XBR450 32" TV
Blurry & Fuzzy Picture Sony Trinitron
Check the filter capacitor to the supply to video output card. You can locate this capacitor at the CRT base card to your Sony Trinitron. Replace this electrolytic capacitor.
Sep 28, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv flickers picture in and out when i first turn it on,but the sound works fine. then after awile it works fine. model # kv-27hsr10 trinitron.
You definitely have a bad capacitor and there are bad grounds that need resoldered. You will have to replace the capacitor or two or three. I would certainly look for those in the 200 volt range to 1Mf to 4.7Mfs as most likely to replace. Also you should resolder the vertical IC chip. This is a most common problem here! Thanks for asking!
Sep 01, 2010 | Sony Televison & Video
Our Trinitron KV-36XBR400 powers up then no picture
How old is this tv?More than 5 years old.Not worth it to repair CRT tv at this prices.Tries unplug,replug an hour later,might help,see if reset itself.U can buy a pretty good 32" LCD tv at $400 or less these day.It not heavy as the CRT tv,it alot easier to move the tv around the house or other locations.
Feb 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Power on
The power board has parts going out on it. A slow decline in performance usually points to a bad capacitor or power transistor. Take a look at the power board. The board will show extreme overheating evidence if you had a meltdown. If it looks clean, maybe it is just a bad capacitor. If you see a capacitor that looks like the top is bulging out, that is a sign of a bad part. Unless you like to solder, consider this tv done for.
Nov 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony kv36fs76u
hi there, your set has a capacitor problem, most of it are on the horizontal section and video section., usually 100 microfarad electrolytic capacitor with a high voltage is damage. try to test some parts. ty
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Televison & Video Logo
183 people viewed this question
Top Televison & Video Experts
Electro Med Services...
