Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool top loader won't spin and I replaced the motor and the coupling too
I heard a loud noise coming from the washing machine, then I smelled what seemed like an electrical burning smell. Noticed the washer had drained but did not spin. When I attempted to turn the spin cycle on I hear a humming sound but no spin. I replaced the motor and the coupling and it still makes that humming sound when I turn on the machine and it wont drain. HELP PLEASE
  • Anonymous Mar 17, 2014
    When it runs I smell plastic burning.
  • Anonymous Mar 31, 2014
    makes noise but won't spin
  • 8 Answers
If your basket appears to be off-center in the opening, and there is evidence of the basket rubbing the front of the plastic tub, then you should check out my post at:
http://www.fixya.com/support/t1254687-duet_washer_very_loud_when_spinning
If this is what happened to your washer, the 'burning smell' you refered to was the plastic tub getting hot from the rubbing of the basket (mine smelled the same way, I originally thought there was an electrical failure).
Posted on Nov 18, 2008
  • 63 Answers
Its your timer if just humming not running
Posted on Nov 15, 2008
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Won"t spin or agitate. Makes a loud rattling noise
If this is a Whirlpool manufactured TOP LOADER (such as Roper, Estate, Kenmore, Amana, and Frigidaire), you may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. Common symptoms include the following:
1. No spin or agitation.
2. Washer will fill and empty.
3. Drive motor still runs.
4. Strange rattling, grinding or clicking noise during agitation or spin cycles as the drum sits still.
If your washer is exhibiting these symptoms, then its probably a safe bet that the motor coupling is bad.
The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Dec 17, 2010 | Kenmore 24032\24036 Top Load Washer
Won't spin
Will it drain if it will drain your motor coupling broke inbetween the motor and transmission
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer top load
The clicking is coming from a bad drive coupling:
Top loader repair tips
Feb 20, 2009 | Whirlpool Inglis IP4400 Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Nov 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LSC9355DQO won't spin and makes grinding noise
grinding noises are never a good sign. My best guess is that the motor coupling is shot. Very inexpensive repair if you're handy. unplug and tip the machine back. locate the motor and remove the clips holding the motor/pump assembly to the transmission. carefully remove the motor and if the coupling is shot, replace. put it back together and should be good to go.
Aug 22, 2007 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
823 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
