Question about Sony Handycam DCR-HC90E Mini DV Digital Camcorder
Firewire connection I bought my Handycam in May this year and immediately was able to connect it to my PC via firewire connection and capture video without any trouble. I only did this in one session and left it for a while. Now it is 5 months later and I have tried again to do the same and my PC can't/ won't recognise the Camera/hardware. I have tried reinstalling the software, I've bought a new firewire cable, I've checked to see that I have the most current driver for the 1394 port, I have tried capturing using other software than that supplied with the camera and I've connected the camera to the PC in a myriad of different sequences. I've found the first step guide with software not very helpful at all and the manual with the camera doesn't really tell you much either. I am wondering whether there is a setting on the camera itself that needs to be on or off. I've scrolled through the menu items 4 or 5 times but nothing is jumping out at me. Please is there anyone who might be able to help as I need to use the camera for a project soon and I need to be able to edit the footage I'll be getting. Help anyone, thanks,
SOURCE:
SOURCE: Capturing Footage with Camera
USB streaming does not work for Windows Vista. Use the firewire/ilink connection instead.
Roger
Posted on Mar 17, 2008
charcois
  • 763 Answers
SOURCE: Sony DCR-TRV530 firewire connection not recogized on Mac; won't import or capture video
try to use USB wire and then install the driver to your pc. hope that helps you!
CHARCOIS
Posted on Aug 21, 2008
welcomejee
  • 10594 Answers
SOURCE: How do I transfer vide from my Sony Handycam DCR-HC30E to my Laptop?
You can download User Manual and required software (USB Driver) for your Sony DCR-HC30E from Sony Support.
Thank you.
Posted on Oct 21, 2008
  • 51 Answers
SOURCE: unable to connect Sony DCR-PC3 handy cam to my pc
make sure that you are using the correct firewire plugs (4 pin on the camera and 4 or 6 pin on the computer depending on the computer). If you are sure you have all this correct, check your BIOS settings for a disabled media card or 1394 controller.
Posted on Apr 10, 2009
SOURCE: capturing video from a Sony minidv drc36 to a Dell precision
with sony mini dv handycam how to capture on pc
Posted on Aug 22, 2009
My device is connected. Ulead VideoStudio says: Either no video capture driver is install. Where can I find the driver for Sony handycam DCR-TRV30E
  • The USB connection only allows transfer of pictures and movies stored on the Memory stick. The videos recorded to DV tape is NOT accessible through the USB interface. You must transfer taped videos using i.Link.
  • Go get a Firewire (also known as i.Link and IEEE 1394) cable to connect to your computer's Firewire port. Adding a Firewire PC card is relatively inexpensive, but make sure that card has BOTH the 4 pin and 6 pin connections, for most flexibility.
  • Once you connect the camcorder with the Firewire cable, the Ulead VideoStudio will see the camcorder as a video capture device, without additional software or drivers.
Feb 23, 2011 | Sony Video Cameras
How do you capture footage on a miniDV cassette from a Sony DCR VX-2100 Digital Handycam on to a PC?
If you have Windows Movie Maker installed, this would be very easy. Just connect the Camcorder via the FireWire supplied. Go to Windows Movie Maker and select CAPTURE from device
Feb 19, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
Hi All, I have DCR-TRV238E Digital 8 Handycam... I want to transfer the recorded video to my computer... Can you please tell me where i can download the software to upload the video on to my computer...
All of pre-HDD cam does have FireWire port somewhere in it (or at the docking station in case of SONY's)
In order to capture the footage from the cam to your PC,you need the Firewire card and the cable.Should be available at any computer hardware store.All you have to do is to install the card to your PC,connect your cam to your computer via the cable,then capture the video by your favorite video editing software.
Yes,that sounds a bit more difficult than drag-and-drop work in USB-connection camera,but not too difficult to understand,of course.
Aug 07, 2010 | Sony Handycam DCR-TRV260 Digital Camcorder
Just bought dxg506v from a guy, but it did not have the cd rom for the driver with it. Where or how can i get the driver?
If your camera have firewire port,you need no further software.Firewire connection is in every PC's std. hardware list.So you can plug your camera to your via firewire cable and start capturing your footage immediately.
Aug 06, 2010 | DXG Technology DXG-506V DV Digital...
I have sony trv33 and windows 7 using firewire 1394 port and cable computer does not recognise camcorder when turned on
Your camera will not be recognized when you connect it via firewire. To transfer the video from your camera to your computer you will need a video editing program that is able to capture video from camcorders connected via firewire.
You can try Windows Movie Maker for Windows 7. Alternatively your can search through the internet to find a more advanced video editing software.
Regards,
nicolasiac
Feb 03, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
Sony PC110E video camera that is not recognised by PC
Buy a 4 to 4 pin or 4to 6 firewire cable (depending of Your PC model). Connect it to PC. In any case, the system must to recognize firewire device and capture the images. If PC don't want to see Your cam via direct firewire connection it means the firewire out is broken and needs to be repaired.
Sep 10, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
Unable to connect Sony DCR-PC3 handy cam to my pc
Apr 10, 2009 | Sony Handycam DCR-PC3 Mini DV Digital...
My computers do not recognize sony dcr-hc28 camcorder
Hi, I'm from the Philippines. I have the same handycam model. The first time I connected it to my PC (Windows XP) via firewire, nothing happened. It cannot detect my handycam. I returned the firewire card to the shop where I bought it. They tested it and the firewire card is ok but the firewire cable is defective so they replaced it. When I got home, I tested it again but still the handycam cannot be detected by my PC. I went online to find a solution and I came upon a solution that you need to attach/connect your charger to the handycam before you connect your handycam to your PC. It said that the handycam needs a steady supply of power to be able to connect to the PC. It sounded weird but I tried it and BINGO! The handycam got detected. I was able to capture my videos.
I also have a TV Tuner & Capture Card but when I capture videos thru the RF cables, the videos losses quality and videos are blurred. Thats the reason I bought a firewire card.
May 04, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Video capture problems
Sounds to me that the bit rate on your PC or capturing device is not as high as that now available through the firewire ports. Try increasing the bit rate in your settings and see if that helps. Or have you always used firewire?
Aug 19, 2007 | Sony Handycam DCR-TRV19 Mini DV Digital...
Help loading video to computer
A problem in the Fire wire connections would presumably affect the quality in a quite severe way: you would get large blocks of wrong color or misplaced DCT blocks, the capture would fail altogether from time to time, or something like that. Check the plug in!! Daniel
Sep 13, 2005 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-HC90E Mini DV Digital Camcorder Logo
56 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
