Laptop adaptor is beeping, not charging laptop. What do I do?
    President:
  • 1,314 Answers
The adapter needs to be replaced.
Thanks and please take a moment to rate as fixya.
Posted on Nov 08, 2008
How can I log on when dell laptop only beeps
The beeps may be a code unless it's only one.
Depending on age or power source, it may not be able to provide multiple beeps before dying.
Mar 14, 2015 | Dell Computers & Internet
How do i determine the meaning of one long and two short beeps on a dell inspiron 2650 laptop ?
Hi Glen Growe,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    Now check and let me know if there are any status lights and if the computer still beeps. If yes, observe what type of beeps are emitted from the computer.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Feb 25, 2015 | Dell Computers & Internet
Turn on. No screen. 6 beeps followed by 5 beeps.
Hi Anonymous,
Now check and let me know if there are any status lights and how many times the computer beeps?
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Feb 23, 2015 | Dell Computers & Internet
NEC Versa p8210 Laptop Power Shut down fault
The beeping ounds like overheating, assume you cleaned out the laptop cpu fan and heat sink when you had it apart?
The shorting issue that you refer to, indicates that there is an internal fault in the circuit that carries the DC power to the board. I would dismantle the laptop and try to power it on on an insulated bench, to see if you can spot any arcing as the Adaptor is plugged in. Check the board and look for the inline ceramic fuse, use a multimeter set to the OHMS scale and test the integrity of the fuse to see if it is carrying a current (battery out and unplugged from mains obviously). Then look to see if there are any blown or burned capacitors and resistors on the board or any burned circuit traces.
Also try a different adaptor and check the output voltage of the old one
Jun 21, 2012 | Computers & Internet
Hp530 turn off suddenly
Get a power charging adaptor from HP (if a smart adaptor) or a generic anywhere that matches your spec. Your device is doing what mine did, but in addition mine beeped softly as a warning of failure. Being a smart adaptor, I had to order one from HP, a generic won't work.
Sep 05, 2009 | HP 530 Notebook
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Laptop not showing light, power button not turning on, AC adaptor light constantly beeping faintly
Unplug the power cable... Hold the power button down for 15-20 seconds... Plug cable back in and check for light... If this still didnt work, then unplug cable again, take battery out, wait 10 seconds.... Put battery back in, plug cable back in and this should allow you to boot...
Feb 05, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
David Payne
David Payne
