Question about Remington Smooth and Silky WDF-3000 Electric Shaver
Battery changing how do i open this shaver to change the batteries?
I have a Reminigton (PG-250) beard trimmer that is very similar in appearance. I was able to get to the battery by inserting a small screwdriver into the botton (where it plugs in) and twisting the bottom and top halves apart. There are no screws. Once you get it started, just go around the groove and pry it apart.
Posted on Jan 31, 2009
geokohler
  • 304 Answers
SOURCE: battery replacement
I have the .PDF file from remington for disassembling your shaver for you. Also this model is known for poor battery life and I recommend replacing the NiCd batteries with Lithium Ion batteries of the same size. This will give you much more shave time and 10 time the number of recharge cycles. Post me an E-mail address where you want me to sent the instructions to you or you can just E-mail me and request the instructions and I will attach the .PDF to my reply letter ( geokohler@gmail.com). If you enclose your number I will call you for free and walk you through the process.
I hope you find this information valuable. If you do please take the time to rate this a FixYa. If you ever need my help again post it here and I will be notified of your need for further assistance by E-mail. I do this for a hobby so there will never be a charge.
Sincerely
George
Posted on Jul 28, 2008
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: Remington R 9170 shaver
http://www.remington-products.com/manuals/ib_mftitaniumu.pdf
In the PDF instructions it describes how to remove the batteries. The instructions fail to mention that there is a spit of yellow glue that is holding one of the batteries to the curcuit board with a death grip. Undoubtedly, you will have to use a knife, not in the glue, but on the skin of the battery. Pull on the teather wire, and slice the battery skin around the glue.
If after removing the batteries, and you are not thouroughly discusted with the manufacturer, then purchase a couple of AA Ni-cad batteries solder the positive of one battery to the negative of the other. then solder the free positive end to the red wire, and then the blue wire to the free negative end. Then try to remember how to reverse the process and put it back together, without leaving any parts out. ;-)
There is a risk of injury by overheating the battery when soldering. That should be avoidable if you remember how to drop solder. Just like its name, it involves having the wire securely held in place. Then hold solder iron over the wire/battery end. Then take some rosin-core solder and apply the solder to the hot tip. Then make sure the newly melted solder lands on the contact. Keep in place until it cools and holds the wire to the battery.
If you think this is better than writing to Remington complaining that they did not make it easier and use contacts, instead of solder, so we can simply pop in a new set of batteries. Or maybe look at other manufacturers, and see if they are any better.
Posted on Dec 28, 2008
  • 5 Answers
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
brector3
  • 1612 Answers
SOURCE: How can I change the rechargeable batteries in my
Batteries for your shaver must be soldered in place. You will find battery pack for this model at shaveroutlet.com. Link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To replce, first open the shaver by removing the two screws on the back. The back cover can then be removed and you can access the batteries. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this repair yourself, shaveroutlet.com can do it for you. See info link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Posted on Sep 20, 2010
Testimonial: "Clear explanation which explained why I could not do the repair myself and would have to send it to a repair facility"
Change battery
The batteries need replaced. You will find the correct batteries at shaveroutlet.com at the link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-battery-pack-for-most-norelco-more-p-278.html
To open the shaver you will need to remove the back cover by removing the two screws. You may need to slide the trimmer up to reveal second screw. Inside, you will need to remove the metal clip that is in the way.
Use the tutorial video at the link below for information on changing the batteries
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Oct 06, 2013 | Philips Philishave HQ7850 Electric Shaver
Charge does not last
The batteries have aged out. You have to change the batteries. If the batteries are inbuilt then you have to open the cover and replace the batteries.
Note: If your unit in new and under warranty then do not open your self. Talk to the manufacturer. Otherwise your warranty will void.
Feb 15, 2011 | Grundig Avantgarde Pro 8875 Electric...
I have a Braun Flex XP 5614. It´s some years now, and I have to charge almost every second day. I thought it would be smart to change the batteries, but how? I have removed the two screwes, but I...
You will find the correct batteries for model 5614 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
To open shaver, first remove the two round or oval screw covers on the bottom of the shaver. Then remove the screws underneath, The can then slide the outer case of the shaver down and off of the shaver inner body exposing the batteries
Nov 20, 2010 | Braun Flex XP 5614 Electric Shaver
How I change the battery and what is the cost of a battery.
If the shaver still works but just will not hold a charge as long as it should, you can fix this by replacing the batteries. If the shaver is dead and will not run and the green charging light no longer illuminates when you plug it in, you will need to change the whole circuit board.
You will find the batteries and the circuit board with batteries at shaveroutlet.com. You can order which you require by viewing the links below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
http://shaveroutlet.com/shaver-replacement-parts/braun-printed-circuit-board-with-batteries-p-106.html
To open the shaver, you will need to pry out the two round plastic screw covers on the bottom then remove the screws underneath. You can then remove the outer case by sliding it down and off of the shaver bode. Then remover the black plastic cover inside to access the circuit board and batteris.
If replacing the entire circuit board, you will simply lift it out and replace. If just replacing the batteries, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Nov 05, 2010 | Braun Flex Integral 6520 Electric Shaver
Battery does not hold a charge very long. How do I open the razor to change the battery pack and what battery do I use?
You will find the correct battery type at shaveroutlet.com. See installation tip on item page. You will need two batteries
You will find instructional video showing how to disassemble shaver at shaveroutlet.com also. See link below. It's the 4th video
http://shaveroutlet.com/video_tutorials
Oct 14, 2010 | Braun 360┬░ Complete 8985 Electric Shaver
How to open remington ms3 1700 electric shaver to change battery and battery type??
Your shaver model is not designed to replace the batteries. To open it, you have to remove the side grips on oscillator housing which are glued on. Disassembling it will cause it to be all marred up.
shaveroutlet.com has an easy and inexpensive solution. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms31000-lower-unit-p-567.html
Oct 04, 2010 | Health & Beauty
Hello, How do I change the battery on the Remington TF300 shaver? and I don't know how to open the case to remove the old battery.
Remove the foil assembly and cutters. You will find 2 screws on the back near the top. Remove screws and you can then pry the front half of case off. You will then be able to access the batteries. There are two batteries connected end to end. You will find replacements at shaveroutlet.com. See link below. You will need to order 2 batteries
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Sep 25, 2010 | Remington Health & Beauty
After charging razor will not turn on no power how to open razor to replace battery if that is the problem
Most likely, the battery just needs to be changed. Open the shaver by removing the two screws near the bottom on the back of the shaver.<br /> You will find the correct battery at shaveroutlet.com. See link below<br /> <br /> <a href="http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html">http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html</a>
Aug 25, 2010 | Norelco ReflexPlus 6853 XL Electric Shaver
My remington ta 4570 suddenly won't charge or even run off the power. the light won't even come on. I know its an older model, but I don't use it that often. any ideas? Thanks
When batteries go completely bad, the shaver will stop working altogether. Most likely, you will just need to change the batteries. But you should open the shaver and inspect it first to make sure there is not a lot of corrosion or any burnt spots on the circuit board.
You will find batteries at shaveroutlet.com. See link below. You will need two batteries.
Apr 22, 2010 | Remington MicroScreen3 TA-4570 Electric...
How do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
Remington Smooth and Silky WDF-3000 Electric Shaver Logo
665 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
