Question about JVC Televison & Video
Hello, I have a JVC LT32X576 LC TV Manfg in Aug 2005. I was watching and it turned off on its own, I thought that the sleep timer got turned on so I pushed the on button on the remote and nothing, pushed the power button on the side, nothing, checked to see if the unit was getting power and it was 121.7 Volts. I took the back cover off and checked the fuse, it was blown, I replaced it with a 250V 6.3 Amp fuse (same specs as on the blown fuse and stated on the board) and the blue power light came on as soon as I plugged it in, I tried turning it off but no responce, after about 30 to 45 seconds I can turn it off by pushing the main power button, and back on again but you have to wait 30-45 sec to be able to turn it back. The only thing that turns on is the blue LED nothing else. The relay clicks when the light turns on and off.
  • derekmance Nov 08, 2008
    The relay has always clicked when the TV comes on and off.
    Brigadier General:
  • 6,966 Answers
Primary suspect would be the Power Supply board. Most models uses a common PSU P/N LCA90348. This is based on your post that the main fuse blew. It still could not be ruled out that any of the other boards/components are not faulty. The best approach would be to reference a service manual or at the very least a schematic diagram with voltage readings. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
  • 4,889 Answers
Well the clicking noise is usually an indication that the power supply has failed. You will have to replace the PS board.. If your tv is under extended warranty then you can make use of it to get it fix "Free of charge". Otherwise you can either get a tech to fix it or try fixing it yourself provided you have the experience.You can search for the part at www.partstore.com
  • 435 Answers
There are many things that can cause a television not to turn on.
Some problems can be:
GA_googleFillSlot("TL-IMU-Article"); as simple as an internal fuse, while others are more complicated, like a defective board or power supply.
There are things not even related to the TVs power system could cause the set to be dead. Given the wide variety of possibilities, there is no chance of making a remote diagnosis. Like a blind man in a shooting range, any guess would be a shot in the dark. That's why, you'll need to contact a JVC service center. Once they inspect the TV, they will be able to tell you what went wrong and how much it will cost to fix it.
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
I need to know the service mode of JVC TV flat screen
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
Mar 18, 2011 | JVC AV-32S575 32" TV
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
No action shutoff was activated. How do I turn
Go in ur tv menu go to SETUP.Check for Sleep timer might be on.This timer have setting like 30 60 120 mins.Turn off the sleep timer tv well not auto shut off.Check ur remote control might have a button said sleep.
May 28, 2010 | Panasonic TH-46PZ800U Plasma TV
How to turn on the sleep timer with a comcast
press tv,press setup until 2 blinks,enter 994,press setup briefly,enter049,press the button you want to put the sleep timer on or off
Jul 10, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
My tv screen is green
there is a code to reset the HDMI video, i think it is--hit Display on the remote, then sleep timer and video statice at the same time, then the number 2, then turn the tv off, after it shuts down all the way, turn it back on, should take care of it
Jan 09, 2009 | JVC HD-61G787 61" Television
Blown fuse
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 11, 2017 | JVC LT-32X576 32 in. LCD Television
Sleep timer has been activated and i cant turn it off
Your T.V.s Sleep Timer feature is a programmable automatic timer that will turn your TV off after a certain amount of time. Just reprogam it to the amount of time you want. You probably find that in the menu of your T.V.
Thanks!
Jun 20, 2008 | JVC AV-27D502 27" TV
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
My TV turns off by itself. How do I correct this? JVC TV TURNS OFF IN 2 SEC. AFTER TURNED ON SLEEP TIMER LIGHT FLASHES. BYPASS POWER RELAY
it could be a memory error or a main power supply malfunction.please contact the nearest repair shop.
Jan 07, 2008 | JVC AV-27230 27" TV
Televison & Video Logo
150 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
