Question about Motorola Talkabout T5950 (7 Channels) 2-Way Radio
T5950 2-way hi im having a problem with my 2-way radio. my children used to play with it. but when i took it from them. the other radio cant receive anything form the other radio. i tried having the same channel but still not working. but the other radio is working fine. it can receive alert call, and voice talk. but the other one cant. so pls. anyone can help me? probably it felt of the floor? of they push wrong button?
  • 1 more comment
  • girlyoudream Nov 10, 2008
    hi BENIMUR, i really appreciate your help so much. but sadly my radio still not working. i did paired it with the same channel/frequency, but still not working. allow me to explain it clearly. i have 1 pair of radio w/c is motorola t5950. the radio 1 is working fine, like it can receive alert call/voice talk and all that. meaning when i press the talk button and the alert button, the radio 2 can get the alert call and voice talk. but if you do it on the radio 2, the radio 1 cannot get any of it. and what you can see on both screen are: batt info, dark filled small radio, sound wave sign, Qt and both same frequency/channel number. hope you can help me pls...thank you! goodday...
  • Anonymous Nov 12, 2008
    Same problem for t5950 and kids were playing with it. One radio working fine other not receiving any transmission including weather reports.
  • girlyoudream Nov 20, 2008
    thanks for your help benimur, but sadly my radio still not working.
    Brigadier General:
  • 6,966 Answers
Initially, pls check that the displays of both radios are identical. This is important to establish that the channel/frequency, Interference eliminator settings and all others are the same that both are paired. In some instances, the radio settings may not be changed if it is locked. Top unlock, press on the MENU button for about 3 seconds. For all other settings, pls refer to the user's manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
  • Louie  Role
    Louie Role Nov 10, 2008
    Hi again,
    Appreciate the postback.
    Pls try:
    • verify that the Interference Eliminator Code (0-99) are identical. This would be the small two numbers upper right hand of the channel number;
    • press & hold the MON button (lower right of the display) of radio #1, there should be noise coming out of the speakers;
    • press & hold the MON button again of radio #1 and transmit on radio #2.
    Cheers.
  • Louie  Role
    Louie Role Nov 20, 2008
    Appreciate again the update. Unfortunately, this could only mean any of four (4) things:
    • the mic of radio#2 is defective;
    • the speaker of radio#1 is defective; or
    • the encoder of radio#2 is defective;
    • the decoder of radio #1 is defective.
What are the best dogs for children?
im sad to say you cant trust any animals around children but you could try a golden retriever my neighbour has one and it was raised around children since a puppy i hope this helps you ??
Apr 17, 2017 | Dogs
Why does the mic attachment on my cb radio cause receiving & output problems?
did the radio do well at the cb shop you took it to? when you re-installed it in your vehicle did you change the coax? You may think about taking it to another shop for a second opinion as to whether or not the radio was actually tuned.
Oct 17, 2015 | Radio Communications
It always says im blocked from msp wene I log in can you help me plz? I need my account
when you played it, then it locked up, possible virus, lots of games have let you play them, only to stop letting you play and blocking you from playing
Mar 03, 2015 | Computers & Internet
Can any body help I just bought a cobra 29lxeu multi standard radio is there a problem with the receive on these radios as had this radio hooked up to my homebase antenna on my homebase im...
What you describe is not standard for this radio. It should receive as good as any of the others you have. Are you sure you have all the knobs and switches set right. This radio is more complicated to operate than the previous versions. I personally do not operate one of the new LXs but I do seem to recall they have a RF Gain knob. This should be turned clockwise all the way. Look through the manual. You will be surprised and some of the features the radio has you didn't know about.
Aug 18, 2013 | Cobra Radio Communications
I cant get my surround sound to work with my satelite
If your Receiver is generally playing surround sound under normal circumstances, for eg playing radio or CDs and what ever else you may use it for, then it should play anything you have connected to its various inputs in the rear.(look for -Audio in-, you may need RCA plugs which are most common)
If your satellite receiver box has audio out sockets you need to connect this to one of your auxillary inputs on your Receiver. if it doesn't have this, you need to use the audio output from the television to your Receiver.
Providing that you have sound when using you satellite, its a matter of transferring that sound through what ever device you wish to use, eg, Receiver, Amplifier, Headphones.
Kazon69
Feb 01, 2011 | Audio Players & Recorders
AVIC F900BT Right side speaker audio is very soft or missing when using ipod. The radio and CD player play fine. I have all the latest firmware and Map updates. This problem has been ongoing for at...
Hi! I too have been experiencing the same problem as you only I have been losing the volume on the left side. I took it to my local car audio store but they were wanting to charge to repair it. Have you found a solution?
Sep 20, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
My children have spongebob t.v but they have lost the remote controle to it ! how do i get the t.v to play the dvd player if i dont have the remote ?
you cant. go to radio shack and get the RCA 4 device remote model #RCR4383N $10.00. use the directions to program it automatically. just did my son's tonight, works like a charm. use the input button at the bottom to switch to and from AV input.
Nov 05, 2009 | Emerson SpongeBob SquarePants TV
PIONEER DEHP3500 ONLY VOLUME BUTTON WORKS PLAYS CD BUT BUTTONS DONT WORK ON CD EITHER RADIO DOES NOT WORK AT ALL
hi im using pioneer DEH-5750MP pnly sound is working and no other button is working ,cd is working fine but cant acces the radio as no other button is working
Jun 08, 2009 | Car Audio & Video
My magnum when i key up it blows the fuse,what could it be?
check your aerial for open/short circuit/power wiring to cb in truck/upgrade the fuse by 1 amp/mike wiring (tx/rx) if the cb shop could'nt find anything wrong then the faults in the truck/aerial/power? or the cb shops not up to much! you could have a faulty output transistor in the cb if all else fails?
May 09, 2009 | Magnum S6 Base CB Radio
Motorola Talkabout T5950 (7 Channels) 2-Way Radio Logo
160 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
