Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Remove heat sink,make cpu body.
I have intel pentium 4,3 ghz processor.i reremove heat sink on processor because it was melt and when i on cpu no display was showing in monitor.now after remove the heat sink when i switch on the cpu it is made body and the processor cooling fan make stop after running few second and a bip sound is coming up.pis solve the problem
  • nitroaddi Nov 08, 2008
    can i use anything else as heat sink .
You're a *******
Posted on May 29, 2009
  • heckleyou896 May 29, 2009
    You're a Dumba&&
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
You removed the heatsink and then turn on the PC???
a pentium processor get fried in 2 min without heatsink, and how heatsink can melt may be it is the fan holder i suppose that melted.
the system get too hetaed may be the fan wasnt working or the environment is so hot arround the system try using some extra colling system for your pc.
Posted on Nov 08, 2008
    Novelist:
  • 208 Answers
IF I UNDERSTAND WHAT YOU ARE TRYING TO SAY I BELIEVE I UNDERSTAND MOST ENOUGH TO SAY YOU HAVE VERY SERIOUS PROBLEM AND NEED TO STOP EVERYTHING RIGHT NOW UNTIL YOU FIX CPU!! YOU HAVE SERIOUS OVERHEATING PROBLEM AND ARE PROBABLY CLOSE TO KILLING YOUR WHOLE SYSTEM!! A PENTIUM 4,3GHZ PROCESSOR PUTS OUT A LOT OF HEAT AND THAT IS WHY THE HEAT SINK MELTED, BUT YOU CAN'T RUN WITHOUT REPLACING IT WITH SOMETHING ELSE BETTER THAN WHAT YOU HAD THAT DIDN'T WORK! THIS IS WHY THE WHOLE SYSTEM IS SHUTTING DOWN. IT IS SAYING, IT IS WAY TO HOT TO RUN AND WE ARE GOING TO SHUT DOWN BEFORE WE BURN UP!!! YOU MUST GET MORE COOLING INTO YOUR CASE AND ONTO THAT PENTIUM PROCESSOR AND GET MORE HEAT OUT OF THE CASE. YOU MAY NEED TO ADD ADDITIONAL FANS OR VENTS, BUT YOU HAVE TO REPAIR THE DAMAGE BEFORE YOU RUN THIS MACHINE OR YOU WILL FRY IT!! THE MOTHERBOARD CAN'T TAKE THE HEAT EITHER! REPLACE THE HEATSINK WITH AN ALUMINUM ONE, NOT THAT PLASTIC ONE FROM DELL, AND MOUNT A FAN ON TOP IF NEED BE. YOU HAVE TO THINK COOOOL!!! YOU HAVE THE POWER, BUT IT ISN'T GOING TO DO YOU ANY GOOD IF IT GOES UP IN SMOKE! I'VE BUILT TO MANY MACHINES TO SEE ONE FRY FOR OVERHEATING. YOU SHOULD HAVE AT LEAST FOUR FANS IN THAT CASE, NO COUNTING THE ONE ONE THE VIDEO CARD OR THE ONE IN THE POWER SUPPLY.
DO IT RIGHT AND SHE WILL LOVE YOU FOR IT AND PURR LIKE A KITTEN! NEED HELP-REPLY TO: ARCLIGHT1217
Over heating pentium D HELP
the heat sink needs to be mounted tight enough to make the heat transcend and out to prevent the failsafe mechanism from shutting the system down.
May 08, 2013 | Intel Pentium D 820 Smithfield 800MHz FSB...
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
From where i can download sounddriver for intel pentium 4 of 1.70 GHz processor
sound drivers are for motherboards what is your motherboard numbers is it a 478 cpu or 462 cpu without board i can not help you jim
May 15, 2011 | Intel Pentium 4 1.7G, 1.7 GHz...
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
Mar 22, 2011 | HP Pavilion a775c (A775CB) PC Desktop
Want to upgraded Pentium 4 2.8 GHz to Pentium 4 3.2E GHz
Yes, it will work just fine, as you can see for yourself - on the mb's link is the third processor from the second group (Prescott).
Jun 03, 2010 | MSI PM8M-V Motherboard
Heating problem?
You could get an Intel Water Cooling kit
Jul 11, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computer hangs after 5 minutes from boot
Check the CPU fan (working) and heat sink as these over time clog up with fluff and dirt overheating CPU also check the rear of power supply for blocked ventilation holes
Jul 20, 2008 | Intel Pentium 4 1.7G, 1.7 GHz...
New processor
Usually you can use Northwood-core CPU-s on mobos with Willamatte-core CPU. But is important (exept core) - FSB support of your new processor. Which model of your CPU? What the mainboard use (model)?
Nov 15, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
606 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
