Question about U-Line Echelon (CO2175FS01) Compact Refrigerator
U-Line CO2175FS-00 Echelon
I have a stainless steel U-Line CO2175FS-00 Echelon. The handle is lose. I have taken the door off but cannot figure out how to access the inside of the door to tighten the handle. Any advice??
Thanks.
  • 93 Answers
Depends, if you have the later models, you can able to retighten it a the handle, it is removeable, but if you have the old version, too bad, you have to replace the whole door. You can try to call U-Line at 800-779-2547 to see which one you have.
Posted on Mar 02, 2010
Dishwasher door handle
Remove the screws around the inside of the stainless steel door panel, once you can gain access, repair or replace the door handle and return the door panel to normal.
May 05, 2016 | LG Dishwashers
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
Whirlpool stainless french door refrig...need to take handle off bottom freezer door so I can move it out of house. Is this possible without taking off the whole door?
it is much better to remove the complete door instead of handle . there are 4 screws inside that will release the complete door . if your want to do the handle use a credit card and insert it between the handle and door to release . but if stainless it some times leaves marks on door . i always remove the doors as one door is ever and i mean very costly.. mm hope this helps mm feed back pls ..
Nov 08, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
I have a ksbp25fkss side by side fridge and the door handle on the freezer is loose, but the handle is not the one depicted in the manuel. the handle must be tightened from the back or inside of the door....
you should have trim below and above the handle if not then and its a stainless steel door then there is small round opening on the side of the handle you'll need allen wrenches once you loosen the allen the handle slides up or down then you will be able to tighten the stud post screw then reverse the mounting -----------------be cautious of scratching the stainless steel door when removing the handles
Sep 01, 2009 | KitchenAid KSCS25FKSS Side by Side...
Loose door handle on 511 model
I assume it is a factory stainless steel handle. There are set screws on the floor side of the standoffs. If you look at the bottom of the stand of you will see a small whole about 3/16 in diameter, inside this is a set screw. I cannot remeber the exact size but it is pretty small. Be careful when you are tightening not to scratch the stainless finish.
Jan 03, 2009 | Sub-Zero Bottom Freezer Refrigerator
Loose door handle on ge profile dishwasher
Take the inside panel off.  The 2 screws near the latch only need to be loosened.  Once the handle is off, you will find an allen bolt inside the shaft of the handle support.  Tighten and you are done.
Dec 20, 2008 | GE Profile PDW9880NSS Stainless Steel...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
How do I fix loose handle?
havnt worked on that but... most times theres a cap or piece that will come off hiding the screw not sure what yours is cant find anything on it .. hope that may help some
Sep 02, 2007 | GE Monogram ZDWC240NBS Stainless Steel...
U-Line Echelon (CO2175FS01) Compact Refrigerator Logo
173 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
