Question about Microsoft Windows Server Standard 2003 for PC
Cannot Open DSA.MSC file error
When I tried to open AD Users and Computer on my Server I got the following error message.
MMC cannot open the file "%SystemRoot%\system32\dsa.msc
  • 2 more comments
  • VM_HARDIK Dec 02, 2008
    ANY .MSC FILE CAN'T OPEN
  • uniqst3r Dec 25, 2008
    cannot open services.msc all msc files not opening
  • Anonymous Dec 30, 2008
    S sir ... can u tell me whats the reason for this problem .. and kindly send me the solution for this .
    thank & regards,
    Sudheer Raju
    sudheerrajjd@gmail.com
  • itisallen Jan 21, 2009
    I have the same problem after I did a repair install on the server. Adminpak.msi didn't help.
In my case, the file was already there, and had been working for a long time prior. Making a copy of the file, and calling it something else (dsa2.msc), then pointing my shortcut to that, corrected the issue. Why? I have no idea. This same thing has just happened on a second device also -- surprised there are not more posts about this situation out there.
Posted on Nov 22, 2011
    Problem Solver:
  • 9 Answers
MMC cannot open the file "%SystemRoot%\system32\dsa.msc This may be because the file does not exist, is not an MMC console, or was created with a later version of MMC. This may also be because you do not have sufficient access rights to the file.
Run Adminpak.msi to install the missing management consoles.
And use the latest version for the same.....
reply if this works out.
thank You
Posted on Nov 15, 2008
  • 1kewldude Jun 15, 2011
    I was faced with similar issue today, Just open MMC and install the problematic components.
    SIMPLE.........right?
2 Suggested Answers
ArcAiN6
  • 152 Answers
SOURCE: Cannot Open DSA.MSC file error
When you install the Administration Tools Pack on a computer that is running Windows XP Professional x64 Edition, the Active Directory Users and Computers MMC snap-in file (Dsa.msc) is installed in the %windir%\Syswow64 folder. Additionally, the computer's file system maps the Active Directory Users and Computers MMC snap-in to the following path: DriveLetter:\%windir%\Syswow64\Dsa.mscHowever, the Active Directory Domains and Trust MMC snap-in incorrectly specifies the path of the Active Directory Users and Computers MMC snap-in as follows: DriveLetter:\%windir%\System32\Dsa.mscWhen the computer's file system tries to locate the Dsa.msc file from within the Active Directory Domains and Trust MMC snap-in, Mmc.exe is run. Mmc.exe is run because the Dsa.msc file is associated with Mmc.exe. When Mmc.exe is run, it uses the following path to locate Dsa.msc: DriveLetter:\%windir%\System32\Dsa.msc DomainPathAfter the Mmc.exe command is run, the Active Directory Domains and Trust MMC snap-in tries to locate the Dsa.msc file. Because the Dsa.msc file does not exist in the %windir%\System32 folder, the error message that is mentioned in the "Symptoms" section is generated.
To resolve this problem, manually copy the Dsa.msc file from the %windir%\Syswow64 folder to the %windir%\System32 folder.
Your hardware manufacturer provides technical support and assistance for Microsoft Windows x64 editions. Your hardware manufacturer provides support because a Windows x64 edition was included with your hardware. Your hardware manufacturer might have customized the Windows x64 edition installation with unique components. Unique components might include specific device drivers or might include optional settings to maximize the performance of the hardware. Microsoft will provide reasonable-effort assistance if you need technical help with your Windows x64 edition. However, you might have to contact your manufacturer directly. Your manufacturer is best qualified to support the software that your manufacturer installed on the hardware.
For product information about Microsoft Windows XP Professional x64 Edition, visit the following Microsoft Web site:
http://www.microsoft.com/windowsxp/64bit/default.mspx (http://www.microsoft.com/windowsxp/64bit/default.mspx) For product information about Microsoft Windows Server 2003 x64 editions, visit the following Microsoft Web site:http://www.microsoft.com/windowsserver2003/64bit/x64/editions.mspx
Posted on May 30, 2009
How to fix access denaid probems.
Open the Local Group Policy Editor Applies To: Windows 7, Windows 8, Windows Server 2008 R2, Windows Server 2012
You can open the Local Group Policy Editor by using the command line or by using the Microsoft Management Console (MMC).
To open the Local Group Policy Editor from the command line
  • Click Start , type gpedit.msc in the Start Search box, and then press ENTER .
To open the Local Group Policy Editor as an MMC snap-in
  1. Open MMC. (Click Start , click in the Start Search box, type mmc , and then press ENTER .)
  2. On the File menu, click Add/Remove Snap-in .
  3. In the Add or Remove Snap-ins dialog box, click Group Policy Object Editor , and then click Add .
  4. In the Select Group Policy Object dialog box, click Browse .
  5. Click This computer to edit the Local Group Policy object, or click Users to edit Administrator, Non-Administrator, or per-user Local Group Policy objects.
  6. Click Finish .
Jan 28, 2016 | Computers & Internet
Tip
WINDOWS SHORTCUT
Windows key + R = Run menu
This is usually followed by:
cmd = Command Prompt
iexplore + "web address" = Internet Explorer
compmgmt.msc = Computer Management
dhcpmgmt.msc = DHCP Management
dnsmgmt.msc = DNS Management
services.msc = Services
eventvwr = Event Viewer
dsa.msc = Active Directory Users and Computers
dssite.msc = Active Directory Sites and Services
on Apr 04, 2011 | Computers & Internet
Tip
Some Keyboard Shortcuts
Keyboard Shortcuts
[Alt] and [Esc] Switch between running applications
[Alt] and letter Select menu item by underlined letter
[Ctrl] and [Esc] Open Program Menu
[Ctrl] and [F4] Close active document or group windows (does not work with some applications)
[Alt] and [F4] Quit active application or close current window
[Alt] and [-] Open Control menu for active document
Ctrl] Lft., Rt. arrow Move cursor forward or back one word
Ctrl] Up, Down arrow Move cursor forward or back one paragraph
[F1] Open Help for active application
Windows+M Minimize all open windows
Shift+Windows+M Undo minimize all open windows
Windows+F1 Open Windows Help
Windows+Tab Cycle through the Taskbar buttons
Windows+Break Open the System Properties dialog box
Accessibility Shortcuts
Right SHIFT for eight seconds........ Switch FilterKeys on and off.
Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.
Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.
SHIFT....... five times Switch StickyKeys on and off.
NUM LOCK...... for five seconds Switch ToggleKeys on and off.
explorer shortcuts
END....... Display the bottom of the active window.
HOME....... Display the top of the active window.
NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.
NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.
NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.
LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.
RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.
Type the following commands in your Run Box (Windows Key + R) or Start Run
devmgmt.msc = Device Manager
msinfo32 = System Information
cleanmgr = Disk Cleanup
ntbackup = Backup or Restore Wizard (Windows Backup Utility)
mmc = Microsoft Management Console
excel = Microsoft Excel (If Installed)
msaccess = Microsoft Access (If Installed)
powerpnt = Microsoft PowerPoint (If Installed)
winword = Microsoft Word (If Installed)
frontpg = Microsoft FrontPage (If Installed)
notepad = Notepad
wordpad = WordPad
calc = Calculator
msmsgs = Windows Messenger
mspaint = Microsoft Paint
wmplayer = Windows Media Player
rstrui = System Restore
netscp6 = Netscape 6.x
netscp = Netscape 7.x
netscape = Netscape 4.x
waol = America Online
control = Opens the Control Panel
control printers = Opens the Printers Dialog
Miscellaneous
Windows key + E = Explorer
on Dec 30, 2009 | Computers & Internet
DSA.MSC file is missing in windows server 2003 service pack 2
try reinstalling SP2 http://www.microsoft.com/downloads/en/details.aspx?FamilyID=95ac1610-c232-4644-b828-c55eec605d55&displaylang=en
Mar 07, 2011 | Microsoft Windows Server Standard 2003 for...
Tip
Most Often Used Keyboard Shortcuts.
Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system.
Some More RUN menu Commands.
  1. iexplore + "web address" = Internet Explorer
  2. compmgmt.msc = Computer Management
  3. dhcpmgmt.msc = DHCP Management
  4. dnsmgmt.msc = DNS Management
  5. services.msc = Services
  6. eventvwr = Event Viewer
  7. dsa.msc = Active Directory Users and Computers
  8. dssite.msc = Active Directory Sites and Services
  9. devmgmt.msc = Device Manager
  10. msinfo32 = System Information
  11. cleanmgr = Disk Cleanup
  12. ntbackup = Backup or Restore Wizard (Windows Backup Utility)
  13. mmc = Microsoft Management Console
  14. excel = Microsoft Excel (If Installed)
  15. msaccess = Microsoft Access (If Installed)
  16. powerpnt = Microsoft PowerPoint (If Installed)
  17. winword = Microsoft Word (If Installed)
  18. frontpg = Microsoft FrontPage (If Installed)
  19. notepad = Notepad
  20. wordpad = WordPad
  21. calc = Calculator
  22. msmsgs = Windows Messenger
  23. mspaint = Microsoft Paint
  24. wmplayer = Windows Media Player
  25. rstrui = System Restore
  26. netscp6 = Netscape 6.x
  27. netscp = Netscape 7.x
  28. netscape = Netscape 4.x
  29. waol = America Online
  30. control = Opens the Control Panel
  31. control printers = Opens the Printers Dialog
ALT + Tab = Switch between windows
ALT, Space, X = Maximize window
CTRL + Shift + Esc = Task Manager
Windows key + Break = System properties
Windows key + F = Search
Windows key + D = Hide/Display all windows
CTRL + C = copy
CTRL + X = cut
CTRL + V = paste
Will add some more soon .. Hope its helpful for you guys.
on Dec 19, 2009 | Computers & Internet
Dsa.msc not opening
try to reinistall or repair your windows.
May 30, 2009 | Microsoft Windows Server Standard 2003 for...
How to repair dsa.msc it is not working
Reboot your DC in Directory Services restore mode and then try again. If you have a backup, then restore the backup.
Let me know if you have any queries.
Regards,
Abhay.
Apr 08, 2009 | Microsoft Windows Server Standard 2003 for...
Active directory
hello,
we have a following command option to open active directory:
dsa.msc
thanks,
Sep 30, 2008 | Microsoft Office Outlook 2003 for PC
Microsoft Windows Server Standard 2003 for PC Logo
3,497 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
