Have a 50 cd player and whilst moving unit a cd is stuck so cannot open unit
  • jbib Nov 08, 2008
    it is a panasonic about 12 years old
  • Terry Rodgers Jr.
    Terry Rodgers Jr. May 11, 2010
    HOW OLD IS IT & WHAT BRAND?MODEL # PLEASE!!
    Scholar:
  • 131 Answers
Model # ?
Posted on Nov 09, 2008
  • Terry Rodgers Jr.
    Terry Rodgers Jr. Nov 13, 2008
    the model # is usually located on a metal plate or sticker on the back of the unit.i need this in order to help you.thanx for using fix-ya.
The door opens whilst playing cd's
What type of disc player is this. Is it a mini sytem all in one unit or what? Give better details (Please)
Nov 09, 2012 | TDK Audio Players & Recorders
AVIC - Z1 Screen no longer retracts to allow insertion of a CD
One of the pistons that move the screen in place must be stuck. The unit must be taken apart to fix this.
You need to take the tablet at a replair shop
Jul 30, 2008 | Pioneer AVIC-Z1 Car DVD Player
CD stuck and will not come out of player
Almost all CD players have an "open" over ride. Look for a small hole or rectangular opening on the side of the unit near the front. Using a tiny screwdriver, carefully insert it and gently move it back and forth. It should give an audible click, and release the CD.
Nov 02, 2012 | Cars & Trucks
I just bought a used pontoon boat with a Clarion Marine M235 radio/cd player. The previous owner said there is a cd stuck in the player and won't eject or play. The display says "no cd" but I...
you have to open the unit cover to remove the CD, its probably tried to eject it and its past the point that shows one in the slot which is causing the player to say NO CD , once opened, use great care in moving anything, and keep track of where everything goes,
Jul 04, 2011 | Audio Players & Recorders
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
Cd is stuck inside the player. I moved the unit when decorating and now the unit will not play any cds and there is one stuck inside. I removed the casing to look inside but got scared off when I saw all...
It is safe (except for the lead solder) as long as the unit is not powered ON.
There is a "pin hole" on the front of the CD tray.
With power OFF, use a stylus (straightened-out paperclip) to push the mechanical eject button inside the pin hole. Carefully use enough force to push the CD tray out.
Oct 13, 2009 | Audio Players & Recorders
Got a hp pavilion 564a computer - can't get the cd player to open. Seems to be stuck.
I fixed the problem by restarting my PC, then continually pressing the eject button whilst having the CD player flap open ( use a small paperclip or the like ). I did this before the Windows screen appeared. This method I got from the hp website.
Aug 18, 2008 | Computers & Internet
I have a Ford AU Fairmont fitted with a Ford Radio/6 CD disc player.The radio works well but the disc player will not load or unload and there is no indication as to what discs are loaded.This action took...
more than likely something got stuck or broken ..
You will need to open it up and see if there is anything you can notice that may be causing the problem. more than likely the loder. if you think you can move it back into place or frmove the jammed components then by all means do. if not take it to an electronic technician.
Jul 20, 2008 | Car Audio & Video
My portable cd player is acting weird all of a sudden! HELP!!!!
You need to open it up to check the parts inside. First look around to see if there is any plastic parts that are damaged. This might account for the noises inside. If you can not see anything wrong. Get a magnifying glass or lens and look at the lazer lens. Make certain the power is NOT on for any of these tests. If you see any odd light patterns or damage on the lazer lens it will not play discs. Unless it was an expensive model it will not be worth repairing if the lens is damaged. Do not open the unit if the model is still under warranty. In which case contact the maker of the unit.
May 05, 2017 | Lenoxx Electronics CD-50 Personal CD...
The cd is stuck
Some CD/DVD units have a manual opening mechanism, it looks like a small hole on the front of the unit, try using a needle or a metal rod that fits by inserting it into the hole and pushing it should open the unit in case it got stuck somehow. If afterwards it continues to work then all's good else you'll have to bring it to a workshop.
Sep 30, 2005 | Pioneer AVXP7000CD Car Video Player
21 people viewed this question
 Grubhead
Grubhead
