Question about Avanti Top Load Washer W797
Avanti w798ss doest start
The machine fills with water and then just hangs. I just bought this washer. I'm guessing that something's wrong with the sensors because the machine doesn't seem to recognize that its filled with water and should start washing. I'm super fustrated and can't figure this out! Help!
  • zouzouka Nov 17, 2008
    I don't hear any click when I close the lid....I am really frustrated I don't know what to do.
    Thank you
  • Anonymous Jan 15, 2009
    same problem !!!!
  • 3 Answers
Close the lid! There's a sensor on the back hinge of the lid. Make sure its working. You should hear a small click when you close the lid.
Posted on Nov 09, 2008
Whirlpool Ultimate care 2 washer doesnt fill on start or rinse or spray in spin all other functions fine whats wrong?
The water valve has a 'Hot' and 'Cold' side, make sure to test if the unit will fill at a different water temp. setting, as a Cold/Cold setting will paralyze the machine if the Cold side of the water valve has failed... Some newer machines have temperature sensors attached to the valve and will not fill if the sensor fails... Washing Machine Water Inlet Valve 285805
May 23, 2016 | Whirlpool Washing Machines
How do I troubleshoot if My kenmore washing machine fills with water and then stops
It is more than likely the lid switch. Most modern machines will fill with water and then wait for the lid switch. If it is bad they will just sit there.
Jun 27, 2014 | Kenmore 22422 Top Load Washer
Fills with waters starts making a buzzing sound
Check to see if there is something(sock) in the pump. If not, try spin washer with pump hanging down, but not with hoses off.
Jan 12, 2010 | Whirlpool Washing Machines
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
We have a GE top load washer with the model number WDSR2120J. It new (almost 13 months old so the warranty has just expired.) When we turn it on, it won't stop filling up when it is full. Bubbles then come...
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling into the washer, then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. Also, the pressure supply tube connected to water level/pressure switch may have a hole in it or a bad connection, or possibly plugged up. This rubber tube must have an airtight seal at both ends to perform properly. be sure to check this item also. Happy to help, Tim.
Jul 01, 2009 | General Electric WDSR2120J Top Load Washer
Kenmore series 70 will not fill
Ive only run across this a couple of times in my years of appliance repair. This sounds like you do not have an air gap on the drain hose. Where the hose hangs into the wall drain pipe make sure you do not have that sealed air tight with duct tape around it or something. It needs to have a gap all the way around the hose and just hang freely. If it is sealed off then it creates a siphon effect and sucks the water right out of the washer tub into the drain.. Hope this helps.. Thanks
Feb 18, 2009 | Kenmore 22422 Top Load Washer
The water doesn't stop. The machine fills with water and never stops. I just bought this washer. I'm guessing that something's wrong with the sensors because the machine doesn't seem to recognize that its...
I'm not familiar with your model washer, but most overfill problems are attributed to either a fill valve that does not shut off properly (this is where the fill hoses connect to), or a pressure switch malfunction. The pressure switch is what determines at what point the washer shuts off. Since you just bought the washer, I'm assuming the water inlet valve is probably NOT an issue, because the problem I mention with it not shutting off, is usually attributed to sediment build up. The pressure switch is controlled by a pressure hose and an electrical connection. If the electrical connection is intact (no corrosion or broken wires) and the air hose is connected and has no holes or slits, I would rule that you may have a bad pressure switch. However...It is common for the air air hose to come loose on the pressure switch and fall off. This can happen through normal use due to vibration, or during shipping. The result: a pressure switch that no longer senses the water level and will not shut off. This is easily resolved by re-attaching the air hose. What appears to be a very serious problem can often be something as simple as reconnecting a hose. Now...if you just bought the appliance, I would NOT recommend you open it to inspect. Most appliances come with a limited one-year manufacturers warranty. You can void this warranty by opening the appliance. This is the only time I would recommend you place a service call. I know this may be an inconvenience to you, but the service should be FREE if still under warranty. If you end up damaging something attempting a repair on your own, the repair would be YOUR responsibility. If you cannot find your sales receipt, the appliance serial number will determine the manufactured date and the warranty should STILL be honored. I hope this helps you. Let me know if you still have questions.
Nov 08, 2008 | Avanti Top Load Washer W797
Front loading washer
if washer is turned off doeas water still come in? if so suspect fill valve if not suspect small hose from tank on left rear corner either plugged or crimped almost closed if hose cks ok suspect water level control
Sep 24, 2008 | Frigidaire Washing Machines
Bosch washing machine
With no clothes in the washer start a program. The washe level is below the door glass. the rinse level comes up 3 cm on the glass. The washer is designed to be water efficent. If you are not getting water this high, look at the pressure switch hose, maybe it is restricted and causing the pressure to be held in the washer.
Jan 19, 2008 | Washing Machines
Avanti Top Load Washer W797 Logo
345 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
